Nice Job! My only concern is the weight of the duel sub box. I had mine only a few weeks and the inside of the rear tires started to wear( because the camber angle changed ) so I switched to a single. Keep an eye on those cool new treads and rotate frequently.P.S. If this is a problem, you might be able to change the camber angle to offset the weight( get the tires straight up and down ) J.S.D.
