I was at a store the other day picking up stuff for the house and remembered that I needed some washer fluid. They had a generic kind and a Turtle Wax Bug and Grime at the same price. I opted for the Turtle Wax one since they were the same price and figured why not with the extra additives (not actually sure if there are or not) in it.My issue is ever since I poured it in, the fluid doesn't want come out at times. Some times it will spray out the back, but not the front and vice versa, as well as not come out at all. I highly doubt it the washer pump(s) since it was working perfectly before hand and since it will, on occasion, spray just fine. Has anyone else had issues with this brand of washer fluid?My only remedy that I can think of right now is to try and waste it, well when it does spray.Any thoughts or ideas would be greatly appreciated.
That's a weird one, I haven't ever had fluid do that. I have used that stuff before but never had any problems with it.I would be inclined to suspect the pump but if it's doing it for both front and rear I don't see both pumps crapping out at the same time... At least I think there are two pumps...If it is the fluid and you can't get it out via normal means, I guess you'd have to pull the reservior. Or maybe somehow siphon it out of there via the filler neck.
One thing I think worth mentioning is that when it was warmer thatn the freezing mark, the fluid sprayed fine, but sub freezing is when it's had issues. Although the bottle says protects to -25, is it possible that I may have received a bad batch that didn't contain tha agent that keeps it from freezing?
That sounds like a valid theory. I was going to ask if it was for winter use also. You could add some methyl hydrate to increase the antifreeze properties instead of disposing of it.
Quote, originally posted by Wolfman213 »Methyl hydrate??? What exactly is that?It's the antifreeze agent in windshield washer fluid. You can get it at most hardware or chemical supply stores. I upgrade mine with it in January and Feb. when the temps get down to -30° or worse. It's also used for model airplane engine fuel among other things.
You can add rubbing alcohol to it too. Washer fluid and alcohol are the ingredients in 'homemade windshield deicer.' Probably not far off of the effective ingredient in the commercially available ones...
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
I'm going to try some rubbing alcohol this morning since I already have some of that. I know that it's supposed to get warmer tomorrow so I will probably just purge the system, if it lets me, and then get some of my normal washer fluid and hope that everything works fine then. Thank you all for your input!!
A hair dryer or heat gun on low would also help to loosen up the lines. I'm cautious about putting anything like the bug remover stuff in my fluid, it could be harmful to the lines and pumps used in the system. Having a de-icer in the fluid or a bug remover additive is helpful, but is it proven to be safe and effective in long periods of time or non-use sitting in those little lines which are nothing more than what you use to put air in your fish tank.
yeah... this thread is what i thought of when i went to walgreens to pick up some wiper fluid.... i walked right past the turtle wax and got my regular gallon...
de-badged o4 vibe
o2 triumph speed four
