Hello everyone.I feel like this is such a newby question, but can anyone please tell me how to get to the DRL module? I know where it is located, but can't seem to find any way to get in there.Thanks a lot,Ben
Hi. Sorry I wasn't more descriptive. I have an 04 Vibe. The problem isn't doing the mod, I have all my instructions - it's just gaining access to where the module is. I see if I'm on my back above the gas and brake pedals that I can see pretty much everything but can't get in there to do any work. I would like to just take that part of the dash off, but can't find anywhere on how to remove it.Thanks so much,Ben
Pull off the bottom of the steering column, there are three screws. Then lying on your back you should be able to get your right hand up from under the dash, and your left hand in through the hole you just made. It's a bit of a pain, but you're only in there for a minute...
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
