Both my front fog lights are broken. The right one needs the housing as well. So I was looking for something like this:http://cgi.ebay.com/ebaymotors..._1442Yay? Nay? or something better?Also the front (right) bottom grill is missing. Any places where to find one? Thanks a lot.
What year Vibe? The fogs you link to will require some work to get them to fit, they're not a drop in.If you want a direct replacement, http://www.partszoneonline.com/ has stock fogs for around $75 complete (not sure if it comes with the bulb). Or keep checking eBay for replacements.For lower grille, if eBay or a local junkyard doesn't have one, the same place sells them for about $18...
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
Quote, originally posted by keithvibe »your better off with thesehttp://cgi.ebay.com/ebaymotors...A1318I knew they had to be on there, just too lazy to look
I'll throw this into this fog light post as well.... When I did a set for another member here, I had to swap the factory adjuster screws onto the new lights... I can't recall why now though... something about the pivot on the one end I think.... take one out and compare very carefully to make sure everything is the same..
Quote, originally posted by vibe11 »i thought 9006 went into the fog lightsthey do, but with a little mod the 9005 fit and are brighterthe 9006 has a frosted black "cap" on the end of the bulb- 9005 is all clearthey both work
Quote, originally posted by CAN-AWD-VIBE »they do, but with a little mod the 9005 fit and are brighterthe 9006 has a frosted black "cap" on the end of the bulb- 9005 is all clearthey both worki replaced my fogs with 9005 -- you can tell the difference and the mod takes about 30 secs...
Quote, originally posted by bull77 »i replaced my fogs with 9005 -- you can tell the difference and the mod takes about 30 secs... i think this will be the first mod of the new year, once it gets warm. my drivers side fog went out before th end of the year; been driving w/out the fogs since then.
de-badged o4 vibe
o2 triumph speed four
