Anyone use Motorcraft 5w20 synthetic blend oil?
scooter
Post by scooter »
Seems pretty inexpensive compared to a lot of the oils out there. Wondering if anyone is using or has used it, and how they like it.
03 AWD Neptune, Auto, Moon and TunesTraded 6/30/2008 for09 GT Red Hot Metallic, 5spd auto, sunroof
djb383
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (scooter)
Post by djb383 »
Use Motorcraft 5W20 synblend in all 3 vehicles. Excellent oil, very good price.
Raven
Post by Raven »
I wouldn't use it in the '09 under warranty, might be an issue.
djb383
Post by djb383 »
'09 Corolla's say 0W20 or 5W20.
Raven
Re: (djb383)
Post by Raven »
I wonder what the '09 Vibe is supposed to use? I assumed it would be 5W30 but maybe not.
scooter
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (Raven)
Post by scooter »
Quote, originally posted by Raven »I wouldn't use it in the '09 under warranty, might be an issue.Why? Because it is a synthetic blend? I thought as long as the ASI standards were met by the oil used, and you still obey the intervals specified in the users manual, that would be ok?
scooter
Re: (Raven)
Post by scooter »
Quote, originally posted by Raven »I wonder what the '09 Vibe is supposed to use? I assumed it would be 5W30 but maybe not.5w20 or 0w20 - both are listed right on the oil cap.
Raven
Re: (scooter)
Post by Raven »
No problem then.
djb383
Post by djb383 »
I believe Honda and Ford have recommended 5W20 for several years now.......and probably would prefer you use 0WXX since 0W is only availabe in synthetic.
prathman
Re: (djb383)
Post by prathman »
Quote, originally posted by djb383 »I believe Honda and Ford have recommended 5W20 for several years now.......and probably would prefer you use 0WXX since 0W is only availabe in synthetic.Toyota has also issued a notice that 5W20 is fine for the 1.8 l engines used in the older Vibes (and Corollas, Matrices, etc.) although they were originally specified to use 5W30 as shown on the filler cap and manuals.
Digger
Re: (prathman)
Post by Digger »
I am thinking of going 0w40 Synthetic for 10,000 Mile. in the 05 that will have 50,000 next change What do you all think?
prathman
Re: (Digger)
Post by prathman »
Quote, originally posted by Digger »I am thinking of going 0w40 Synthetic for 10,000 Mile.Why the higher viscosity (40) rather than the Toyota recommendation for 20 or 30 weight?
Sublimewind
Post by Sublimewind »
I run 0w30 Castrol Syntec in my Subie.. It's the only oil on the shelves that is 100% German made, which holds them to MUCH stricter TUV standards... Running a 0wXX in the general car is totally not needed though... I use it so it flow into my Turbo quickly... It's also a vERY stable oil..
djb383
Re: (Digger)
Post by djb383 »
Quote, originally posted by Digger »I am thinking of going 0w40 Synthetic for 10,000 Mile. in the 05 that will have 50,000 next change What do you all think?Do what you want but here's some good reading from a pretty sharp fella that says thinner is better. http://www.bobistheoilguy.com/aehaas/
Digger
Re: (djb383)
Post by Digger »
the ow-40 is what my new car is calling for. I am more concerned about the 10,000 mile interval. I change now every 5,000. The 10,000 is what the manual calls for in the new car.
djb383
Re: (Digger)
Post by djb383 »
What new car calls for 0W40???????
SublimeVibe
Post by SublimeVibe »
I think the oil is for diesel engines.We ran 0w40 in our large trucks at work.They were stored outside at -40.
2003 VibeAWD Envy(sublime)wCharcoalPower pkg.Enkei EVO5 Hyper Black 07/08Vibe floor matsMud flaps Hood DeflectorLimo tint on rear and side windowsstainless steel insterts
Mojo72
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (djb383)
Post by Mojo72 »
I used the Motorcraft 5-W-20 in the 2006 Focus that I used to lease. As long as I bought by the case, I remember the price to be fairly reasonable.
2004 1.8L (1ZZ-FE) Vibe (Lava Red)16" Michelin Destiny tires
NUBlackshirts
Re: (prathman)
Post by NUBlackshirts »
Quote, originally posted by prathman »Toyota has also issued a notice that 5W20 is fine for the 1.8 l engines used in the older Vibes (and Corollas, Matrices, etc.) although they were originally specified to use 5W30 as shown on the filler cap and manuals.According to the TSB, it is only approved for use in the 1ZZ-FE (Base/XR) engines, NOT for the 2ZZ-GE (GT/XRS).
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
Digger
Re: (djb383)
Post by Digger »
Quote, originally posted by djb383 »What new car calls for 0W40???????I am getting a Smart car. It comes from the factory and calls for 0w-40 every 10,000 mile. My wife will be driving the vibe for the most part. If I change the vibe to synthetic oil I will most likely extend the miles in between changes.
prathman
Re: (Digger)
Post by prathman »
Quote, originally posted by Digger »I am getting a Smart car. It comes from the factory and calls for 0w-40 every 10,000 mile. My wife will be driving the vibe for the most part. If I change the vibe to synthetic oil I will most likely extend the miles in between changes.So why not use the lower viscosity that's recommended for the Vibe in the Vibe and the higher one in the Smart? I don't see any particular reason why you feel you have to use the same oil in both.Frankly I'm a bit surprised at the 40 weight recommendation for the Smart since it goes against the trend toward recommending lighter weight oils both for improved fuel efficiency and for better lubrication in today's engines that are made to stricter tolerances.
Digger
Re: (prathman)
Post by Digger »
I plan on useing the proper viscosity in each car. As far as the smart goes, I do not have it yet and I think the viscosity is dif. for west & south than it is for East & north
I finally have the ability to change the oil in our cars... Was out at mal*wart looking today for oil and found this stuff. I need 5w20 in the Hyundai and the shop I had been bringing mine to was a blend of some description and I kinda liked it... Motorcraft was the only blend they had in stock. You can't beat the price. $11.50 for the 5 quart jug. I seem to be reading good things about it so hopefully all goes well. What kind of life expectancy should I see with this stuff? I was doing 4k changes with the blend from the shop, I trust that would be ok here.
Image Image
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (ColonelPanic)
Quote, originally posted by ColonelPanic » I was doing 4k changes with the blend from the shop, I trust that would be ok here. Should be fine, I see no reason not to do this if it's been working for you in the past!
