Wind leak...
capecodbeachfront
Wind leak...
Post by capecodbeachfront »
I would like to put a heavier weather stripping on the INSIDE of the door where the glass pushes against it. Top of the bottom half of the door. What is this part called?? Is there a heavier version available. Wind noise is coming up the inside of the glass... passenger side.
GOLF THE CAPE !
ou.grizzly
Re: Wind leak... (capecodbeachfront)
Post by ou.grizzly »
I do not think anything is available for that or will work properly because once you roll the window up/down, there will be issues.
keithvibe
Post by keithvibe »
do you have vent visors? if not you may want to try those to help deflect the air away from the window
lowincash
Post by lowincash »
i stuffed some thin weather strip foam in my front window channel and it helped cut down some wind noise.
-- 2009 Vibe GT in Jet Black
