Trans fluid
tribones
Trans fluid
Post by tribones »
OK - After my last oil change I started having some transmission issues. Car doesn't like shifting into gear from cold starts. Lunges when approaching stop signs. Higher revs when shifting. The trans pan appears to have a ring around the drain plug - even though I've never drained it. Has anyone else seen a leak through the drain bolt? I've yet to change out the fluid ( 60k miles ). Dealer guy is going to take the pan off tomorrow to check it out inside.
zionzr2
Post by zionzr2 »
I'm about 3K miles shy of 60K Miles and I'll be doing my second Tranny Fluid Change.Sounds Like its time for change for you.
