Wife lost her keys. How do you program a new key fob. Should I get one made at the dealer or get one cut from our spar key? I think I can get a new fob on E-bay
Quote, originally posted by Digger »Thanks... I did put a bid in on one. The instructions should help out a ton Do you think a dealer key is better than a cut key?Whatever is cheaper. I really see no difference. Just head to a Lowes/Home Depot who cuts keys, get the blank, and get it cut.
The 0.99 + $4 shipping is cheap for a FOB - even if ti is "used". I bought a new one on eBay in 2003 for about $15 total as I have a reputation for losing those things. That was good insurance against losing mine as I never did.I wonder if those FOBS plus a Lowe's cut key would work for a 2009. I bed those keys with the built in remote cost plenty.
Quote, originally posted by Digger »Thanks... I did put a bid in on one. The instructions should help out a ton Do you think a dealer key is better than a cut key?FWIW I prefer a dealer or better locksmith punched key over a ground/cut key, less chance to have funny wear over time.
last of the '06 AWDslava red monotone, preferred, sport, and side airbags
I got one ground cut at the local hardware store. it is a spare and It works great. I got the fob for 4.99 and will use the instructions above to program it. . Does the other one need reprogramed when I program the new one. Or, can I just program the new one?
Just program the new one and you'll be fine... The Vibe handles I think up to 4 remotes so you'll just be adding another one. The original one you still have will continue to work without any additional steps from you.I had mine set up for 3 remotes -- thought I lost one, so I replaced it and come to find out I later found it. I still have that one, need to program it for Kari's Vibe.
Quote, originally posted by Digger »Got the key fob. Used the directions here and it works great. Thanks all.Excellent!Now, get the wife a lanyard for her keys!
