Quote, originally posted by RePo »It's a ground loop alright, and the fix is very easy. I had the exact same symptom with my new audio setup in the Vibe. This has happened in other car's I've upgraded, too. I bought mine on Ebay for much less, but here's the easy source.
http://www.radioshack.com/prod...62214Yeah, you could purchase something to cover your problem, OR, you could simply fix the problem, which like I said is almost 95% of the time a problem with grounds in the audio stream, usually the HU.. Not all grounds are the same and they are getting worse and worse as cars are being glued together more and more every day.. You may find you may have to ground the HU back to the battery, that's usualy in the most extreme cases though..
