My 2005 awd Oil light does not come on when I start the car. Could it be that L.E.D. is burnt out or plug from the harness came loose? How easy is it to remove the cluster to see the back for anything loose. The car runs fine, but check light at the starting of the engine stays off. Any Ideas of what could it be?I would appreciate any suggestion.
Kevera had a link to a 9thgen thread in changing the cluster lights I do believe. - - - Did a search for "cluster" and came up with this. http://www.9thgencorolla.com/f...33261You'll need to sign up for an account to view it. I'm not a member, so I don't know how helpful it'll be for you.Here's a link to the original thread. http://forums.genvibe.com/zerothread?id=29387
