My wife has a 2005 Vibe with a single CD factory stereo (C1 according to the sticky post -
http://forums.genvibe.com/zerothread?id=21818). I just bought one of these (
http://www.soundgate.com/uploa...1.pdf - picked it up at buy.com for $90) so that she can connect her Zune to the aux port on the stereo. I also picked up some T-Tap connectors from RadioShack. From reading the other threads in this forum, I have a pretty good idea what I need to do. I've already had the HU out of the dash and know where everything goes. My questions are around the power connections for both parts of this kit. (Forgive me if these are dumb questions.)First, on page 2 of the instructions, there is a warning that says to disconnect the negative terminal of the battery. Is this strictly necessary, or just a CYA precaution on their part?In step 3 on page 5, is it sufficient to screw the ground lead to the metal stereo case, or should I splice into the ground lead on the main stereo harness as suggested in other posts? Also, they explicitly DO NOT recommend using the +12v constant from the main stereo harness. Again, is this just a CYA precaution, or is this something I really need to worry about? If I shouldn't tap into the main harness, any suggestions where I should tap into?In step 4 on page 5, should I tie the ground lead to the exact same place as I grounded the other component in step 3, or does that matter? For the +12v switched power source, should I tap into the wire that's going to the cigarette lighter, or is that not switched? Or is there a better option?Thanks in advance for any advice you may be able to provide!
