Error Code Too Lean po171
lpj
Post by lpj »
Hi All, About a month ago the check engine light came on. Used a friends scanner and determined it was error code po171 Too Lean (Bank 1). He reset it and off I went. The light came back on Thursday. Friend came over today and same code. The car seems to be running fine. The car is a 2005 Vibe non-turbocharged, automatic transmission. Any infothoughts would be appreciated! Thanks!
keithvibe
Re: Error Code Too Lean po171 (lpj)
Post by keithvibe »
do you have an Cold air intake on it? do you often red line?
lpj
Re: Error Code Too Lean po171 (keithvibe)
Post by lpj »
It's actually my parents car, so not sure of all the specifics, but do know that it is stock (no mods). So I don't think it has a cold air intake, and no redlining
Raven
Post by Raven »
My first cure for any injector, fuel mix code is to run a tank or two of TECHRON. It's worth a try, cheap and cleans the injectors etc.
