fog lights...
Abby-vibe03
fog lights...
Post by Abby-vibe03 »
i am trying to put in some new fog lamps.... i took a look at the set up... and it is different then the head lamps.... while the headlamp set up appears to just pop out.. the fog lamp assembly looks like it has 2.. (maybe more) screws holding it in.... i am not entirely sure as it is difficult to seee... and i didnt find anythin inthe manual for changing them.... anyway just wondering if anyone knows if those screws have to come out in order to change the bulb or if it does just pop out.... keep your stick on the ice!
NovaResource
Re: fog lights... (Abby-vibe03)
Post by NovaResource »
ragingfish
Post by ragingfish »
The entire assembly "snaps" in place...there are no screws holding it in.To change the bulb, all you have to do is twist the the assembly towards the center of the car. Then just pop in a new bulb, and twist it back into place until you feel it lock. You can just reach under the car and do it too.
2009 PONTIAC G8
Abby-vibe03
thanks... i think i can trip through it... any one know the serial code for the fog lamp bulb..... ?/
NovaResource
The fog light bulb is #9006
