Winter tires for 2009 1.8L auto
elkhaze
Post by elkhaze »
Questin 1: Can I install the 15 inch rims on the 2009? Walmart and dealer say you can only put 16" rimms.Question 2: If I get the 16" steel rims from Walmart or Canadian Tire, would the multi-fit rims work or should I buy them from Pontiac/Toyota dealer?
2009 Vibe 1.8L Auto
northvibe
Post by northvibe »
looks like 16"s are only recommended ones. Even Tirerack says so. There could be a offset for 15" that could fit...but its probably because of the brake calipers, arent they bigger on the GT?
dragon64
Re: Winter tires for 2009 1.8L auto (elkhaze)
Post by dragon64 »
I have test fit a set of customers 15" Toyota rims on my 1.8 '09 at the tire shop I still help out at when I'm not at my regular job. Clearance in the front was minimal about 1/16" between the caliper and wheel hoop. Tried a couple sets multi fits from different suppliers one cleared but the other clipped the caliper in one spot must have been slightly out of round.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
