A few monts ago i put an aftermarket air intake and a borla muffler on my vibe. It seems to be running fine, but the cel is on, with a P0171 code. Every now and then it'll go away for a few days or even a week, but it always comes back on with the same code. Could my intake be causing the lean condition?? And if it is how can i fix it?
You could have a vacuum leak after the MAF as well. Another possibility is that if it is a "no-name" CAI kit you installed it may have a bigger that stock tube diameter if it requires you to relocated the MAF sensor from the OE housing to the new tube. Just ran into this in the shop doing R&D for the 2ZR-FE in the '09s where the tubing was one size over diameter and required a plastic calibration insert for the MAF to see the correct airflow.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
WELCOME fellow PA member.Depending on the year and type of Intake.the 05-08 with the drive by wire are know to lean out on the top end with CAI.IF you have a short ram intake it will help limit the lean CEL.
thanks. i tried the maf and i made sure there weren't any leaks, so i ran the Techron through with some high octane gas and it went right out. how often do i have to add this? and is this condition harmful to my vibe?
