I had a loud rear noise from the rear, I thought it was tire noise due to me driving 120 miles a day, but the noise has gotten worse, well today I checked the rear brakes and they were ok but the RR wasn't spinning freely like it should, now I suspect a bad bearing or hub, can I buy the bearing separate? or do I have to buy the whole assembly which isn't cheap and not available around here.Thanks
What did you do to check the brakes?? Often times the Ebrake will not fully disengage.. that could be part of it maybe? Unless you went through all of that.. Not sure about the bearing, someone here will know..
