Royal Purple Max ATF Multi-Spec High Performance Automatic Transmission FluidWill work for your Automatic Tranny as well as your Power Sterring Fluid.This fluid meets the Toyota Type- IV and the Dexron III Specs.So this One Fluid will work in both applications.Royal Purple Stock Number: 01320UPC: 641330013201I am eventually switching to all Royal Purple fluids.I'll drain and refill the Tranny, replace the Power Stearing, and drain and replace the Differental fluid with RP 75w90 probably in the spring at my next oil change.I was getting supplies for the oil change I just got done with and noticed that this 2 for 1 deal was a posibility.
