Bolt pattern
jono.peters
Bolt pattern
Post by jono.peters »
I have somebody offering me these Blizzak WS-50 195/65/15they are on 15" steel 5x110 bolt patternDoes the 110 affect anything?J
cerulean
Re: Bolt pattern (jono.peters)
Post by cerulean »
Vibe uses 5x100 bolt pattern, so the wheels won't fit.You would need to mount the tires to some wheels that do fit.
prathman
Post by prathman »
Yes, the '110' would be important since this indicates the size of the circle on which the lug bolts are located. But 110 mm is not a common size so I'd check to be sure that's really the size for those wheels. The correct circle size for Vibes with a 1.8l engine is 100 mm ('09s with the 2.4l use a larger circle).
Sublimewind
Post by Sublimewind »
100 and 114, never herd of 110... "some" wheels offer dual bolt patterns though, 100 and 114..
shemp
Re: (Sublimewind)
Post by shemp »
While we're on the subject, I see 114, 114.3 and 115... are these all different callouts for the same size or are they 2 or 3 different sizes?Also, anyone know the correct offset on the 2009 vibes? It should be labeled on the backside of the wheel, right?
2009 Vibe GT
prathman
Re: (shemp)
Post by prathman »
The reason for 114.3 mm is that it's equal to 4.5" and I think the ones labeled 114 are also this size. I believe 115 mm is a distinct size.
shemp
Re: (prathman)
Post by shemp »
so 114 and 114.3 are the same, and 115 is different? ...and the vibe has 114/114.3?
2009 Vibe GT
prathman
Re: (shemp)
Post by prathman »
Quote, originally posted by shemp »so 114 and 114.3 are the same, and 115 is different? ...and the vibe has 114/114.3?The Vibes through 2008 and the '09s with the 1.8 l engine have the 5 x 100mm bolt circle. The '09s with the 2.4 l engine have a larger bolt circle (I think they use 5 x 114.3 mm).
Raven
Re: (prathman)
Post by Raven »
5x110 is quite common actually. Pontiac G6,G5,Chevy HHR, Malibu and Saab 9.3 and 9.5 just to name a few.
