Running cable from Back corner to dash
ChuckstrPT
Post by ChuckstrPT »
So, what's the easiest way to run an antenna extension cable from the back right corner XM antenna location to the dash to attach to my Sirius reciever?? notice the word EASIEST....I've run wires from back to front before in my Cherokee...it was not fun, nor easy. Thanks for the help!
05 GT, Abyss Black, all tarted up...
keithvibe
Re: Running cable from Back corner to dash (ChuckstrPT)
Post by keithvibe »
nothing is easy but, the neatest way would be to drop the headliner.
ChuckstrPT
Re: Running cable from Back corner to dash (keithvibe)
Yeh, That's what I did with the Coax from an Amatuer Radio and CB to the antenna's on the rear hatch...it was not fun, but came out very well....there is no trace of the coax...all hidden. Well, I got an extension cable for the Sirius radio...50 ft is all they had to pick from. I'm thinking I could wrap it a few times around the car before hooking it up to the radio in the dash
hskater26
Post by hskater26 »
well if you decide to lower your car you would take off all the inside plastics and that would be pretty easy lol thats what i did with my xm but when i canceled it i had to cut the wire and pull it because i wasnt taking it all off again
-2003 Base Vibe-2002 Ducati ST2
