HELP!!!!I followed the directions and cut the #12 wire, the DRL are off but now the headlights won't turn on at all. Lows, highs, nothing, the fuses are fine too. I went in thru the gauge side because I was doing the 6 speed reverse beep disable as well. Everything there went fine, the beep is off and I am happy but I am kind of freaked out about the headlights.
That link is for eliminating the flicker with HID's. Just for ****s and giggles I cut the wire just below which should be wire #3. DRL stayed on with this wire cut.
as your looking up, laying on your back or side, on the driver sidethe drl wire is on the left hand side of the steering collumIt is a red wire with two white stripeshope that helpsThose are the best photos i can take of the area.LOL
