1zz ----> 2zz
SkateForLife86
1zz ----> 2zz
Post by SkateForLife86 »
Alrite, is a 2zz motor compatible with the 5-speed transmission that comes standard with base model vibes/xr matrix? If so, how much would a 2zz engine be running for? Where would they be available besides a junkyard? thanks
slbpsi63
Re: 1zz ----> 2zz (silverawd26)
Post by slbpsi63 »
I've seen a 2zz motor on ebay for 2G's
Base Vibe, Shadow Monotone, 5sp.
SkateForLife86
i'll try to get pics of my car up this week.
KSNeptune
Re: 1zz ----> 2zz (SkateForLife86)
Post by KSNeptune »
I'd keep your eyes out for a recked Vibe GT. Because they tempt the driver to rev it up for pleasure, I'm suspecting they will be more likely to get into accidents than the base Vibe.KSNeptune
ragingfish
Re: 1zz ----> 2zz (KSNeptune)
Post by ragingfish »
Problem is, though, it might be hard to find one without major engine damage...
2009 PONTIAC G8
Faultline
Post by Faultline »
aslo, if you havent checked it out, then there is a guy over on spyderchat that is doing a 1zz 2zz motor swap in his spyder...it is in the performance mod forums...quote:Alrite, is a 2zz motor compatible with the 5-speed transmission that comes standard with base model vibes/xr matrix? If so, how much would a 2zz engine be running for? Where would they be available besides a junkyard? thanks ....also try car-part.com...they are a good source....also...It would be chaeper just to trade you base in for a gt...or ...get a turbo like me ..I have mor ponies than the 2zz
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
