215/55R16 Tires on 2004 Vibe?
Tarfu43
Post by Tarfu43 »
Hello all. I just purchased an 04' Vibe AWD, which has 205/55R16 tires. I have a brand-new set of 215/55R16 tires from my old car (which met it's demise last week in a deer collision). Is it ok to install the 215/55R16 tires on the stock 16" rims that the Vibe came with? Is there clearance? Will it screw-up the drivetrain somehow?Any comments would be very much appreciated. Thanks!
lovemyraffe
Post by lovemyraffe »
Welcome to the fam! I'm not 100% sure but you should be ok with those tires. I put a bigger tire on mine, but my wife has it right now and I can't remember the actual size.
BlueCrush
Re: 215/55R16 Tires on 2004 Vibe? (Tarfu43)
Post by BlueCrush »
Welcome to GenVibe! You will be fine with 215/55/16's on the stock rims. 100% sure. I had 215/60/16's on my '05 AWD before without any issues.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
kowell
Post by kowell »
Your speedometer readings will be 1.7% too slow so when your speedo reads 60mph you will be doing 61mph which is nothing to worry about.
2009 Vibe 2.4L 1SC - Red Hot Metallic
2011 Sienna V6 CE - Sky Silver
KNINE
Re: (kowell)
Post by KNINE »
Our local BJ's wholesale store has Goodrich 205/60/16 for 75 bucks installed. How will the 60's effect my car? THey're 75,000 mile tires and seems like a really good deal.
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
coldmm803
Post by coldmm803 »
i had 215/55/16 on my vibe for a lil while but my dealer noticed and threatened to void my warranty so i had to switch back. normally, the vibe's speedometer reads 2mph slow so this will make it read correct/faster (according to gps) but will cause the odometer to read slow.
Tarfu43
Re: (coldmm803)
Post by Tarfu43 »
So you didn't notice any handling or wear problems with using the 215/55R16 tires? My Vibe is out of warranty, so that's not a problem for me. I just don't want to ruin anything. It seems from these posts that there isn't any problems with using this tire on the stock rims.
HighMileVibe
Post by HighMileVibe »
Hey, i had the same idea. I will probably pull off the Avid T4's (205/55) and put on some Kumho Ectsa ASX (215/55) - TW 420, AA and A rated. The Avid will then go on my 97 Accord to give me a slightly taller tire on it vs. the 205/50 I currently have.My GPS shows the speedo to be fast by about 5%: 63mph indicated is actually 60 mph. After tire change it should be more like 62 mph for a true 60 mph making speedo MORE accurate - I would throw THAT in the dealers face! They are SHORTCHANGING customers by 5% of their true miles.
2006 Platinum base, Auto, 145k miles+, now a 2004 Matrix 190k+ mods: Leather wheel, Homelink dimming mirror, ribbed cargo mat, blackberry mount, Jensen VM8023HD HU, mudflaps, bumper guard, double armrest Other cars: 97 Accord Coupe, 2000 GMC Savana conversion, 97 Miata M-edition. http://forums.genvibe.com/zerothread?id=37345 http://www.gotlife.org
