Lineage Ground Wire Kit Installed
BlueCrush
Post by BlueCrush »
I installed a Lineage Ground Wire Kit this past weekend. It is a 5 wire, 4 gauge kit. Nice, high quality kit for only $45 on Ebay. There are 5 wires in this kit(18", 22", 26", 32", 38"). They are 4 Gauge ground wires, versus smaller 8 gauge kits, platinum dipped ends and sealed soldered connections. This is one of the best kits out there.Here is how I wired mine:From Negative battery terminal:To driver's side chassis:To Tranny:To rear valve cover:To passenger's side chassis:To Alternator bracket:And here is an overall pic:
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
kevera
Re: Lineage Ground Wire Kit Installed (BlueCrush)
Post by kevera »
Great work B/C.Did you notice a difference in your idle.I want to do this but only if it smoothes my idle out a little.
BlueCrush
Re: Lineage Ground Wire Kit Installed (kevera)
Post by BlueCrush »
Quote, originally posted by kevera »Great work B/C.Did you notice a difference in your idle.I want to do this but only if it smoothes my idle out a little.I haven't noticed a big change in the idle. I know that the warmer the temps get outside, the better my idle gets. It was 81° on Monday here and the idle was super smooth. I'll check it again today since it is only 47° and report back.EDIT: I checked the idle a little bit ago and is idling a little smoother than before. I am also getting a little better shifing and less static on a couple radio staions. So, overall I think it is worth $45.
My Fleet:
tcam
Post by tcam »
looks great Brian I made the the mistake of having one of my ground points at the exhaust manifold, which was very stupid. After 3 or 4 months, the wire was partially melted onto the heat shield, and the end of it was all deformed. lol, should've just ran it to the tranny like u did.
shane_c
Post by shane_c »
So what is this supposed to do?
2006 Vibe (base) - Platinum Silver, 5 spd, ABS, Power Package, Infinity Speakers, Dynomax muffler, Cosmo SR intake - SOLD
XRTIM
Post by XRTIM »
Agreed...excellent work! I especially like the "pics". They will be a great help when I install mine. Thanks BC!
tcam
Re: (shane_c)
Post by tcam »
Quote, originally posted by shane_c »So what is this supposed to do?-gain small torque and hp-better mileage-better throttle response-smoother idle-reduced emissions-brighter headlights-reduced audio noiseall of these things may or may not be noticeable, but that is what extra ground wires are advertised to do. For me, the smoother idle and acceleration is what I was able to notice.
Raivis
Post by Raivis »
do the kits come with instructions??? if so could someone post them. i was thinking about buyign some 4 GA for this. just don't know which wires are being replacedhope headlights are brighter if i roll up two windows at the same time my lights dimm some
You got owned by a wagon..... Life is a sexually transmitted disease!!! check me out at http://www.myspace.com/raiviskysdad
BlueCrush
Re: (Raivis)
Post by BlueCrush »
Quote, originally posted by Raivis »do the kits come with instructions??? if so could someone post them. i was thinking about buyign some 4 GA for this. just don't know which wires are being replacedhope headlights are brighter if i roll up two windows at the same time my lights dimm someThere are no wires being replaced. All existing wiring stays. You are just adding these ground wires to your engine bay.
My Fleet:
02csnow
Re: (BlueCrush)
Post by 02csnow »
Hey Brian i just got my ground kit today and plan on doing it this weekend. Just wondering what lengths you used for each contact point and if you had any other pics.
Bye Bye Vibe.............
damronjr
Post by damronjr »
For some reason I just saw this, but looks good! I never reinstalled my ground wires after the engine ordeal, amongst other things. I have such a list of things I currently own that I have yet to install, we could have a damronjr install meet just to put it all on and spend all day doing it! lol
BlueCrush
Re: (02csnow)
Post by BlueCrush »
Snow: The lengths are 18", 22", 26", 32", 38". I used the 18" from the alternator bracket to the passenger's side chassis.I used the 22" from the driver's side chassis, under the stock airbox to the battery negative terminal.I used the 26" from the passenger's side chassis to the rear valve cover.I used the 32" from the negative battery terminal, under the battery to the tranny.I used the 38" from the rear valve cover to the tranny.
My Fleet:
BlueCrush
Re: Lineage Ground Wire Kit Installed (damronjr)
Post by BlueCrush »
Quote, originally posted by damronjr »For some reason I just saw this, but looks good! I never reinstalled my ground wires after the engine ordeal, amongst other things. I have such a list of things I currently own that I have yet to install, we could have a damronjr install meet just to put it all on and spend all day doing it! lolThanks, Jason. I am getting great use out of your S/C intake tube, too.You should get Mrizzle and Psychobroker to help you out.
My Fleet:
damronjr
Post by damronjr »
Quote, originally posted by BlueCrush »Thanks, Jason. I am getting great use out of your S/C intake tube, too.You should get Mrizzle and Psychobroker to help you out.Yeah, in all the time I have been here I have yet to meet Christian and can't get Mike to come down here for ****!
kunkstyle
Re: (BlueCrush)
Post by kunkstyle »
If a guy wants to make his own kit, what diameter ends do you need to fit the existing bolts?
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
northvibe
Re: (BlueCrush)
Post by northvibe »
Quote, originally posted by BlueCrush »Snow: The lengths are 18", 22", 26", 32", 38". I used the 18" from the alternator bracket to the passenger's side chassis.I used the 22" from the driver's side chassis, under the stock airbox to the battery negative terminal.I used the 26" from the passenger's side chassis to the rear valve cover.I used the 32" from the negative battery terminal, under the battery to the tranny.I used the 38" from the rear valve cover to the tranny.Oh just what I needed! my dad got me thick copper cabling to make a ground kit, just needed the lengths! thanks BC.
Kamikaze
Post by Kamikaze »
Hmm, got me thinking about another mod for the good ole vibe...This might have to be done next weekend. I can't keep up!
August 2009 VOTM Click HERE for my Garage
Sublimewind
Post by Sublimewind »
If you guys decid to make your own ground kits up, MAKE SURE you solder the ends, which WILL require a torch... when you do, do the solder, just heat the very end of the ring and let the heat "wick" up the terminal and wire. By doing this you will melt the insulation the least amount possible... also have a vice or a pair of vice grips handy, to clamp the terminal into right after you are done, i will wick away the heat without getting it wet like if you were to dunk it into a water bath.... Also, make sure you tape or heatshrink the ends well, actually you should do both... tape will seal it well, and the heatshrink will make it look good... Good show as always BC...!!!!
kunkstyle
Re: (Sublimewind)
Post by kunkstyle »
What about a cold solder tool? Or would that not work for this application?
Sublimewind
Re: (kunkstyle)
Quote, originally posted by kunkstyle »What about a cold solder tool? Or would that not work for this application?I highly doubt it would get hot enough.... I personaly think they are a bunch of crap, but, i'm "old school"You have to have enough heat to get the solder to move via capillary action. If you don't you end up with a "cold" solder joint, which is useless... If the solder don't flow, then it don't go.... You can also buy adhesive lined heat shrink... no need for tape...
98ex
Post by 98ex »
Blue, how bought a link to the ebay store you got your kit from(or the seller)
BlueCrush
Re: (98ex)
Post by BlueCrush »
If you do an Ebay search for Lineage Ground Wires - they will come up.
My Fleet:
98ex
Re: (BlueCrush)
Post by 98ex »
Quote, originally posted by BlueCrush »If you do an Ebay search for Lineage Ground Wires - they will come up.This it?http://cgi.ebay.com/ebaymotors...ZWDVWIt does not mention how long the cable is or how many (if they are pre cut)
kevera
Re: (98ex)
Post by kevera »
"4GUAGE, 21MM2 STANDARD OXYGEN FREE CABLE 5 POINT SYSTEM"It doesn't say how long but how many.
BlueCrush
Re: (98ex)
Post by BlueCrush »
Quote, originally posted by 98ex »This it?http://cgi.ebay.com/ebaymotors...ZWDVWIt does not mention how long the cable is or how many (if they are pre cut)Yes, that is the one. I list the lengths after I measured them in my first post. I also list what lengths I connected to which locations a little way up in this thread.
My Fleet:
BlueCrush
Re: (BlueCrush)
Post by BlueCrush »
Added new pics back into the first post.
My Fleet:
milocas
Re: (BlueCrush)
Post by milocas »
I know this thread is old.....But have you notice any difference since 5 months ago?
2003 Pontiac Vibe GT
Herb
Re: (milocas)
Post by Herb »
He doesn't have them anymore. I bought them off him and they just arrived in mail today.Won't have time to do anything about them until maybe next weekend though
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
Sublimewind
Re: (milocas)
Quote, originally posted by milocas »I know this thread is old.....But have you notice any difference since 5 months ago? You won't notice a huge difference, but you may notice a slight bump in milage, easier starting.. dimming lights might be less... it's a support mod..
Herb
Re: (Herb)
Post by Herb »
Well I finally put them on and took a short test drive. It might be all in my head but it does seem to feel a bit peppier and the throttle response seems improved as well.
Sublimewind
That is another possible side benifit to that... The electronics have an easier time recieving current through the system... that's why I mentioned the possible milage bump and easier starting to...
