new photos... of the cut off... they are NICE!This bulbs are 4300kVERY WHITE.... PERFECT!low beamThe highbeam is a touch distorted, but very nice non-the-lessthey offer 4300k5100k6000k8000k10000k
YEAH!!!!!!!!!!!!!! Low beam is the most important, imo, I rarely use the high beams so a little distortion, oh well. Are you still going to wait on the other sample to come int prior to making a decision?
No I told them to hold them. The other kits would be the same, only thing different would be the angel eye and the factory plug.So at this point I asked my contact to get me final pricing.They would ship me all the kits then I would have to ship them out to everyone else.It's better to do it this way, less chance of losing 10-20 kits then one kit that is drop shipped to everyone.
NEW photos... comparo between my stock halogens, with HIDs and ONE projector... ONLY one projectortemp of the halogen reflectors is 6000ktemp of the projector is 4300khttp://matrixowners.com/index....63429
Quote, originally posted by keithvibe »NEW photos... comparo between my stock halogens, with HIDs and ONE projector... ONLY one projectortemp of the halogen reflectors is 6000ktemp of the projector is 4300khttp://matrixowners.com/index....634291. Wolfman2132. milocas3. bull774. Amtron5. GoodVibErations20046. DarkSporkThose projectors are intense. How much for that setup? I'm tired of hardly being able to see anything with my low beams, while I can't use my high beams due to oncoming traffic. Its a nuisance.
By reflectors, I'm assuming you are refering to the chrome part that aids the halogens correct? The anticipation is killing me lol. I can't wait to see them blacked out with the killer projectors!!!!
Quote, originally posted by Wolfman213 »By reflectors, I'm assuming you are refering to the chrome part that aids the halogens correct? yes. they are being murdered as I type this HAHAHA
Quote, originally posted by keithvibe »yes. they are being murdered as I type this HAHAHANICCCCCCCCCCCCCCEEEEEEEEEEEEEEEEE..... this is going to be a great great thing... can't wait for the pics...
hey keith i saw u ovr at hidplanet.com and im jus about to start on my retro for the winter...any sugguestions...i got everything now so all i need is some help and what not
looking great!! so close ahhh I can't wait to see the finished product!!!alinement of of the projectors in the housing or simply alinement once on the vibe?
Quote, originally posted by Wolfman213 »looking great!! so close ahhh I can't wait to see the finished product!!!alinement of of the projectors in the housing or simply alinement once on the vibe?With this kit you use your stock reflector, adjustments. Easy peasy.Think of it as simply replacing your bulb with a new one.
they are in and wired, working, except for my angel eyes, the switch i was going to use, the mounting screw broke, so those aren't wired. Tomorrow..... but there is one problem... it's raining cats and dogs right now and i cant make final fittings and photos.Just before the rain started I snaped a few photos.
got a break in the rain. So i got them adjusted pritty well. After I bake them back together again I will check alinement again and button everything back up.Yes i know they need to be lowered a touch to be closer to my halogen output.Don't be haten, just cuz i'm the first vibe with projectors, other than sema cars. HAHAHADaily Driver baby.
usually most cars come that way...the driver side is slightly lower than the passenger side.looking good so far. but i would highly suggest using a bigger shroud to cover up the projectors? on one of my previous retrofits i didn't use a shroud and the headlights looked like bug eyes lol
The kit comes with new sealant, but i was careful when i pulled them apart so all i had to do was re-heat the glue and press everything back together... If in the next few weeks I have an issue with moisture, I will use some of the provided sealant that came with the kit.
this is a direct copy and paste from MOOk Update time:Took new photos. And got everything adjusted. And here is MY honest opinion.The projectors produce a very nice pattern. HOWEVER, There is a slight upturn on the ends of the light now that they are mounted in the headlight housing. It's the housing causing the issue. Not the Projector. It wasn't there before I mounted them in to the headlamp.I drove around for about 15-20mins tonight after I got the height just right.I didn't have one person flash me, so thats a good sign.As for light out put, I am used to my 6000k bulbs so these seem dimer, because they are 4300k. They throw a decent distance. I can't say for certain that everyone will be happy with these. Everyone is different. But for me they are a huge step up from the stockers. I know everyone is dieing to see more photos.I wish i could compare them side by side with another vibe to see the difference.I will see what i can do to make that happen.Light throwlow beam You can see the slight upturn on the ends, it kinda looks like a "(" the lowest point being in the middleHigh beam
You said something earlier about a switch for the angel eyes right? Is the switch to turn only the angel eyes on/off? Or is it for the whole light? And if not, are the angel eyes always on with the lights?
Quote, originally posted by Amtron »You said something earlier about a switch for the angel eyes right? Is the switch to turn only the angel eyes on/off? Or is it for the whole light? And if not, are the angel eyes always on with the lights?I wired the angel eyes to a switch that is only active when the car is started or the key is turned to the IGN on position.It's just for the angel eye. the projectors are operated by the stock switch on the stalk, along with the highbeam.
great work! looks good =D now it's the fun part...driving it at night haha i must say it's very hypnotizing watching the sharp cutoff go up and down as you drive...it's awsome!
Ok a follow up. The upturn wasn't the head lamp the projector shifted a tiny bit in the housing to cause the upturn on the driver side. All fixed and level again.
The pics i've been wating for... Looks GREAT man.. GREAT work, GREAT cutoff, GREAT overall look... my new favorite mod.. (to bad i'll never get to do it myself)
keith, those are sexay!!!!!!! holy crap. haven't read through the whole thread, but looks like the angel eyes are red... can they be changed to white or blue? if its a stupid question, sorry also how much? how much dammit?!?!?!?!looks suweet
de-badged o4 vibe
o2 triumph speed four
