Tango Charlie 2003 Vibe
Tango Charlie
Post by Tango Charlie »
This is my daily driver, Olivia;Like Trikkoncepts, I'm after MPGs. My grille block just isn't as fancy. I run my tires at max sidewall, but even with it being a 5 speed, I'm averaging about 38 MPG. 20 mile commute, not highway like Triks. It doesn't show up in the pics, but the front end is pretty nicked up. Lotsa stone chips. I've done the 'cut the yellow wire' DRL-delete mod. I like it. I've checked out the site from time to time, thought I'd make a first post.
mac99d
Re: Tango Charlie 2003 Vibe (Tango Charlie)
Post by mac99d »
Look’s real clean. So how much of a fuel savings do you get with the deflector? Have you done a comparison between the two on or off, and are there any overheating issues?
Mac's Vibe.
bull77
Post by bull77 »
Nice job and vibe....you're not alone, my front end is also beaten up with stone chips and scratches
Tango Charlie
Thanks, guys.I've had the grille block installed since September. No temperature issues at all. I've got a ScanGauge II installed (one parameter it displays is coolant temp), so I'm going to go ahead and start blocking off the lower opening, too, now that it's getting cooler...I've noticed a solid 1-2 MPG increase with the block installed. Not a lot, but every little bit helps. You can see a picture-laden thread of its installation here; http://ecomodder.com/forum/sho....html
pick41
Re: (Tango Charlie)
Post by pick41 »
Good looking Vibe, nice to see another Hoosier.
Pick2004 AT, AWD, Moon & Tune2006 - Mazda5 Touring1998 CBR 900RR RIP 10/97-8/08
