how do i replacae my foglight bulbs!?!?!?!?
ramenboy...
Post by ramenboy... »
ok, so a couple weeks ago, i realized the aftermarket headlight bulbs i had were running too hot and melted the h4 socket on the passenger side.finally with some mild weather this weekend, i picked up a pair of high-heat sockets, replaced the stock ones, put in new bulbs and all was good. then i saw that i have a burned out stock fog light. so i picked up some 9006 bulbs hoping to replace the set, BUT i can't get to the freakin lamps from behind!! anyone replace their fogs? i thought this would be easy...
de-badged o4 vibe
o2 triumph speed four
keithvibe
Re: how do i replacae my foglight bulbs!?!?!?!? (ramenboy...)
Post by keithvibe »
twist and unplug, simple as that
ramenboy...
yeah but how do i get to them... do i have to take off the plastic well liner in front of the wheels? that would be a pisser if i did... or do i try to reach down from the engine bay? then i think i need 4 foot arms
de-badged o4 vibe
keithvibe
Re: (ramenboy...)
Post by keithvibe »
take out the two 10mm bolts holding in the plastic liner just under the bumper. you don't need to remove the entire liner.Once you have the liner moved out of the way by pulling it down twards the ground you can access the bulbs very easy.
hskater26
Re: (keithvibe)
Post by hskater26 »
i just reached up in there underneath the bumper....skinny arms/hands helped lol
-2003 Base Vibe-2002 Ducati ST2
Kamikaze
Re: (hskater26)
Post by Kamikaze »
put on hoist, walk under car... twist and pull.
August 2009 VOTM Click HERE for my Garage
