A week after I got my '09 GT, I reset the TP monitor, just for something to do. Worked first time, no problems. I've since increased the air pressure & want to reset it again. I swear I've tried 20 times & it just won't work. What am I doing wrong? Anyone else have the same issue? Thanks
The manual says that if the indicator light doesn't blink three times when holding the button down after a reset, the reset wasn't successful. I gots no blinks.
Quote, originally posted by ou.grizzly »Is there any indications that the spare tire has a sensor in it? That probably doesn't matter. The tire senses pressure by rotation. If the wheels are rotating at a different speed, it suspects one is low.Be sure to put all of your tires to the correct pressure before resetting the system. I'm not sure how to reset it on the 09's though. On my Alero I had to hold the switch until it blinked and then release and press again or something. I just messed with it for a few minutes until the light went off.
Quote, originally posted by NibCrom »That probably doesn't matter. The tire senses pressure by rotation. If the wheels are rotating at a different speed, it suspects one is low.I'm not sure that's true, my tire pressure sensor went off when standing still and filling the tire to the proper inflation. Also this wouldn't make sense when the tires are slipping, as you would trigger the inflation sensor. I've replaced one of these before, I believe they work on actual pressure.
I could be very well be wrong. My Olds Alero had tire pressure sensors and that is how they worked. And, like you said, I would get false readings on occasion. On long patches of rough road the light would come on. I would check the pressures and they would all be fine. That particular sensor did not measure actual pressure.
Up till 08 they are based on rotation speed, not actual pressure. They may have changed that for 09 I have no idea. I thought I read on the boards here for the older Vibes you have to be driving and hit the button and not slow down for a certain number of miles.
-Sean Cummings--Crushed Blue Steel Motorsports-06' GT, Abyss, Leather, M&T, Tint, Roof Spoiler, Magnaflow Cat-Back, K&N Short Ram modified for ram-air, S-Tech's, 18" KV5 Wheels, SLP Ram-Air Hood, paint matched headlights, strut tower brace.Now Making Custom Vibe Sub Enclosures
