LED dome lights from Oznium---LED dome lights from Oznium, Figured out wht size for Matrix, Vibe the same??I am putting Soft white in the rear as "soft is bright enough" and red in the middle dome, so I can turn on dome lights while driving for a short time so my daughter can see her nintendo and such and I figure the red will not glare my eyes and bright white in the sunroof control map light...I also have the Auto dimming mirror with compas that has some led map lights that are designed to be soft on the eyes as well as they are aimed at your lap...
http://www.oznium.com/thin-led-domelightOznium is proud to introduce the slimmest LED dome light on the market. This dome light is made with very bright surface-mounted LED's which are attached to a thin circuit board. It takes only a few minutes to install.Available in four sizes:1.5" x 1.0"1.5" x 1.5"2.0" x 2.0"1.5" x 5"I have tried one and like it so ordered the other two...our dome light will take the 1.5 X 5 inch one if you pop the cover off, then pop out the mount, then trim some of the grey plastic using a dremmel or heck even a wire cutter....just trim 1/8 of a inch, essesentially the "lip" and the 1.5 X 5 fits fine...lots of light and color choices....I did the rear one as a test, and tomorow am doing the fromnt one next to the Sunroof controls with a 1.5 X 1.5 (it measured 1.5 X 2.5) and the center dome with a 1.5 x5 .How to Install1. Pop off the plastic dome or map light lens.2. Pull out the old bulb.3. Find the matching connector (we include 7 common sizes).4. Plug it in, fit the new LED dome light in place, and put the lens back on.That's it! Very easy, and a wonderful looking light when it's done. Seven common bases are included with each dome light.194/168/T10 BA9S Bayonet 27mm Festoon 31mm Festoon 36mm Festoon 39mm Festoon 44mm Festoon Check out Sylvania's Lamp Replacement Guide to find out which bulb size is correct for you.
http://www.sylvania.com/Consum...t.htm
