Brass shifter bushings, do they work?
KNINE
Post by KNINE »
I saw these brass shfter bushings on ebay. Does anybody know if they eliminate that plastic feeling from the 5-speed shifter? I did a search on shifter bushings and didn't find anything. http://cgi.ebay.com/ebaymotors...ZWDVW
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
Raven
Re: Brass shifter bushings, do they work? (K-NINE)
Post by Raven »
They're excellent. One of the best mods I've done. gives a much more precise feeling in the shifter.
Herb
Post by Herb »
It definately helps. As for the plastic feel, that might be because the shifter really IS made of plastic.
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
DarkSpork
Post by DarkSpork »
If anybody decides to go forth with this modification, could you take pictures? I hate the feeling of the shifter in vibe, sloppiest feeling shifter of any car I have driven.
2003 Pontiac Vibe GT
KNINE
Re: Brass shifter bushings, do they work? (DarkSpork)
Post by KNINE »
I just ordered a set today. I'll let you know.
SeattleJeremy
Post by SeattleJeremy »
Looks like I'm a little late to this thread, but yes, they are worth every penny. Much easier to shift, more direct, not mushie.
northvibe
Post by northvibe »
yeah i have them for my ms3, they help with the "slop"
DarkSpork
Post by DarkSpork »
Quote, originally posted by K-NINE »I just ordered a set today. I'll let you know.Thanks. This is one of the few upcoming purchases for the car I'm looking forward to.
northvibe
Post by northvibe »
I just reinstalled my shifter bushings into my car (they were like that aircraft aluminum). WOW i forgot how much they helped. So stock has those rubber bushings in, so the feel is a soft shift, smooth etc. but since its rubber and can move its "sloppy" but easy going. After the bushings were in, its a tight, straight shift feel. Like mechanical. Were you go to shift and thats what your doing, not soft, not smooth but right to the point. Feels good.
bodhi_tree777
Post by bodhi_tree777 »
Hey, K-9, did you ever install these? Just got mine in the mail, was wondering how easy or hard the install was? I've read up a bunch on them and I've seen photos of them installed, but no step by step instructions were included. Also, I've read that I should clean and lube the linkages down there, what would you use to clean them?
DarkSpork
Re: Brass shifter bushings, do they work? (bodhi_tree777)
Post by DarkSpork »
Quote, originally posted by bodhi_tree777 »Hey, K-9, did you ever install these? Just got mine in the mail, was wondering how easy or hard the install was? I've read up a bunch on them and I've seen photos of them installed, but no step by step instructions were included. Also, I've read that I should clean and lube the linkages down there, what would you use to clean them? Hey, would you mind taking pictures of the install for me ?
bodhi_tree777
Quote, originally posted by DarkSpork »Hey, would you mind taking pictures of the install for me ?sure, if I can do it correctly . They may only be good for a laugh, as I've never attempted anything like this before. Seems easy enough though.
DarkSpork
Post by DarkSpork »
Thanks. I've been meaning to do this mode but I don't know how to find the bushing on the linkage.
bodhi_tree777
they're pretty easy to find, actually. Pop your hood and look down past the cruise control, near the airbox. To make it easier, have someone shift through the gears while you're looking. They are the moving parts at the end of the accordian-looking arms. If you can get your car up on jacks or ramps you can see them easily.
DarkSpork
Post by DarkSpork »
Thanks. I'd still greatly appreciate it if you can take pictures for me though .
bodhi_tree777
okay, I'm going to try and get these installed this week. Questions, though.. I've read that the SpeedSource bushings are labeled upper and lower, and are slightly different in size. Mine (which I assume aren't from SpeedSource, i purchased them from a genvibe member here) are exactly the same size. Should I be worried?Also, there's been some debate about whether to use the stock pins that come with the vibe or use the ones that come with the brass bushings. Mine didn't come with any, so I'm going with stock I suppose. Should I be worried about that either?
KNINE
Post by KNINE »
I bought a set of Summit bushings from ebay about a month ago, but I've been too busy to put them in. I can't remember if mine came with pins. I'll have to look when I get home. So I guess I was a big help, wasn't I?
KNINE
Post by KNINE »
I just looked at my Summit bushings and no pins are included, so I assume that we reuse the stock pins.
bodhi_tree777
Quote, originally posted by K-NINE »I just looked at my Summit bushings and no pins are included, so I assume that we reuse the stock pins. are yours both the same size?
KNINE
Post by KNINE »
I'll take a look when I get home from work.
KNINE
Post by KNINE »
Both of mine are the same size.
bodhi_tree777
I meant to get to this today, my last day off this week. Instead, I bit the bullet and bought new tires instead. Goodyear Assurance TripleTreads, the difference is like night and day. Then again, my Yokohamas were like slicks at this point .Bushings go in next week, I hope. Any tips up til then are much appreciated
bonzo4ever
Post by bonzo4ever »
Highly recommended. I got mine for about 23 bucks with shipping. Felt like a whole new shifter when I got done, without spending the $300+ on a short shifter (although that would be nice).
2003 Vibe GT 6-SpeedAEM Short Ram CAIMegan Racing Strut Tower BraceComing Someday: Magnaflow Exhaust
Herb
Post by Herb »
Quote, originally posted by bodhi_tree777 »Bushings go in next week, I hope. Any tips up til then are much appreciated It's alot easier than you might think. The only thing I would suggest is not to install them when parked on grass, in case you drop the pin. In my case TWM provided pins so when I lost one in the grass I ended up using one of the stock pins.I tried taking a photo of where it's at, but it doesn't show well now. I should have done it when I was installing it.
DarkSpork
Re: Brass shifter bushings, do they work? (Herb)
Post by DarkSpork »
Quote, originally posted by Herb »It's alot easier than you might think. The only thing I would suggest is not to install them when parked on grass, in case you drop the pin. In my case TWM provided pins so when I lost one in the grass I ended up using one of the stock pins.I tried taking a photo of where it's at, but it doesn't show well now. I should have done it when I was installing it.Well if you still have the picture it may help me. I guess what I need to do is get it on the lift and have one of my friends fool with the shifter so I can see the linkage moving and from there I should be able to figure out where the bushings are. Thanks.
Herb
Post by Herb »
I didn't need a lift. It can be installed from above and I found it would be easier. This shot is to give you a point of reference, and so I can show off my engine bay...
Herb
Post by Herb »
Here's a close up with the bushings circled
bodhi_tree777
awesome, thanks (and nice bay, btw). Did you have to remove anything to get down there, or did your intake give you enough room? I have a stock airbox so I think I'll have to unbolt and move my cruise control to access these (or get it up on a lift somewhere).
Herb
Post by Herb »
Quote, originally posted by bodhi_tree777 »awesome, thanks (and nice bay, btw). Did you have to remove anything to get down there, or did your intake give you enough room? I have a stock airbox so I think I'll have to unbolt and move my cruise control to access these (or get it up on a lift somewhere). I didn't have to remove anything, but then I already had the CAI installed by that time. I believe you would have to remove the airbox to get access. I don't recall having to remove the cruise control. All you need for tools would be a needle nose pliers to remove the retaining pins
bodhi_tree777
thanks Herb. Last question, were your 2 bushings the same size, or slightly different?
Herb
Post by Herb »
Quote, originally posted by bodhi_tree777 »thanks Herb. Last question, were your 2 bushings the same size, or slightly different?To be honest, I don't remember any mention of differing sizes. I just looked at the stock bushings and they seem to be the same.
DarkSpork
Post by DarkSpork »
Quote, originally posted by Herb »I didn't have to remove anything, but then I already had the CAI installed by that time. I believe you would have to remove the airbox to get access. I don't recall having to remove the cruise control. All you need for tools would be a needle nose pliers to remove the retaining pinsThanks Herb, I think I'm going to order some, it looks pretty easy. And if it makes my shifter feel less cheap and sloppy I will be quite happy. Nice looking engine bay by the way.
Herb
Post by Herb »
Quote, originally posted by DarkSpork »Thanks Herb, I think I'm going to order some, it looks pretty easy. And if it makes my shifter feel less cheap and sloppy I will be quite happy. Nice looking engine bay by the way.It's probably one of the easiest mods to do. I got the ones from TWM when I ordered my short shifter. I installed both at the same time so I can't tell what difference each individual mod had. Guess I should have done them in stages. In anycase the TWM set came with instructions and photos, although it was for a Celica.Let us know what you think of the improvement overall.Thanks for the compliments. I need to take more time to detail the engine bay though.Oh and here's a shot of the short shifter I installed as well
DarkSpork
Post by DarkSpork »
Got them in the mail today, hopefully weather will permit me to install them tomorrow (its supposed to snow again).
DarkSpork
Post by DarkSpork »
Changed the bushings today. It was pretty straight forward, the hardest part was getting the old ones off. The vertical one was the most difficult and the horizontal one had rubber pieces fall off as I pulled the arm off the pin. I didn't have to remove anything, and it took about 20 minutes. Shifting feels more precise, there is less play in the shifter and it seems to go into gear easier, only gear that isn't easy is downshifting into 2nd (but it is much improved from before). This was worth the $28. Thanks Herb for the pictures, it helped me figure out exactly where to look.I attached a picture of the old bushings. Didn't bother to take pictures of the install because there was too much in the way to get a decent picture.
Herb
Post by Herb »
Quote, originally posted by DarkSpork »Changed the bushings today. It was pretty straight forward, the hardest part was getting the old ones off. The vertical one was the most difficult and the horizontal one had rubber pieces fall off as I pulled the arm off the pin. I didn't have to remove anything, and it took about 20 minutes. Shifting feels more precise, there is less play in the shifter and it seems to go into gear easier, only gear that isn't easy is downshifting into 2nd (but it is much improved from before). This was worth the $28. Thanks Herb for the pictures, it helped me figure out exactly where to look.Glad I was able to help. I don' t think I had any problems removing mine, but that's the reason they include some sand paper to help clean out the area in case the rubber bushings fell apart.
DarkSpork
Post by DarkSpork »
Your pictures helped a lot. It seemed that there was nothing I could remove that would really make it any easier.
Herb
Post by Herb »
Quote, originally posted by DarkSpork »Didn't bother to take pictures of the install because there was too much in the way to get a decent picture.That was the same reason I didn't photograph the installation too. And the instructions I got with my bushings were reasonable.
harryyiii
Post by harryyiii »
see attached installation manual
Attached files celica_matrix_tc_corolla_cable_bushings.pdf (728.1 KB)
Herb
Re: Brass shifter bushings, do they work? (harryyiii)
Post by Herb »
Quote, originally posted by harryyiii »see attached installation manualThese were the instructions that came with my set, though printed in B&W. Funny thing was that I tried to find this on the TWM website but was unable to locate it.Thanks for posting it.
