Hey guys, I was here before with my wifes '03 base model.She got rear ended, totaled it out. Since got an '05.I drove it off the lot and didnt' check the coolant, its a little low.So.... I have a half a gallon or so of the long life coolant (red) left over from the last one, and this one has the super long life coolant (pink).So, I called two dealers, and neither one has stated they are compatible.Does anyone have alldata access that they can pull up TSB - PG010-02which is supposed to state the compatibility?I just want to top it off until I determine if it needs a radiator or not.Also, anyone know where I can get an adapter for testing the radiator with an old school pressure tester?thanks!Nick
