Finally got my teins and tokicos installed. Looks great and rides like its on rails. But the rears wheels are cambered in pretty bad and also seemed to be toed in ! And from what I am told there are no alignment adjustments for the rears. I know to wait a week for the alignment job. Just wondering if anyone has had a issue with the rear wheels being adjusted or not adjusted.
I had the same problem. They use shims to align the rear wheels and from the factory, at factory ride height my wheels were almost perfectly aligned. But once I lowered it, they were no longer within spec.I took it in and they replaced the shims. $60 and it was good to go. Just be careful about where you take it. Dealerships arent always the best, but they are usually the only ones with the shims in stock.My best!
