Ground Wire
mwebb
Ground Wire
Post by mwebb »
I just hooked my system up today and I originally used a ground under the long compartment in the back. When i had everything hooked up it did not work, so I tested the connections and the ground somehow had power. So now I have it hooked up to the tie down strap holders.Where are other Vibers grounding there systems at? I like all wires to be hidden, any sugestions?thanks
18in Kaizer PHX II wheels / Toyo Tires / Tint2 way pager system alarm/remote starter2 Eclipse 12's / Eclipse HURemoved cross bars / Custom SBReflective red badge overlays / Red Vent Covers Pics Soon Billet Grill /LED underbodysFront tint / Windshield vinyl My Vibe - http://www.cardomain.com/id/webbsvibe
ragingfish
Re: Ground Wire (mwebb)
Post by ragingfish »
Can't you run it through the firewall into the engine bay?
2009 PONTIAC G8
Sub-Vibe-R
Re: Ground Wire (ragingfish)
Post by Sub-Vibe-R »
I grounded my subwoofer by using the bolt who hold the plastic area in the back.
pissedoffgokart
Post by pissedoffgokart »
I used one of the bolts under the E-brake lever...
mwebb
Post by mwebb »
quote:Can't you run it through the firewall into the engine bay?Yeah that is possible but I was looking for a ground that was closer to the sub box on all my other cars my ground wire was only 18 inches or less.I will prolly just use the ground I have now...Unless I get around to making my custom box..thanks for the input everyone.
quote:Where are other Vibers grounding there systems at? I like all wires to be hidden, any sugestions?thanks In the Matrix subwoofer install PDF at the link that jgvibe posted on thread http://forums.genvibe.com/zeropost?cmd=reply&id=49169 , Toyota says to use one of the rear seat mounting bolts for a ground, accessible by slightly folding forward the rear seatback a little.
