Will this bolt patter fit?
Scootman!
Post by Scootman! »
I am currently looking for the best deal on snows and steel rims and came accross this ad for the rims. Will the bolt pattern fit an '04 base and would the tire size be too small or can 14's work on Das Vibe?http://chicago.craigslist.org/....html
keithvibe
Re: Will this bolt patter fit? (Scootman!)
Post by keithvibe »
no 14 tires and rims are too small for the vibesmallest you can go is 15"
engineertwin2
Post by engineertwin2 »
I can't view CL from work, but if they aren't 5x100mm, then they won't fit. If they come from a '03-'08 Matrix, Corolla, Vibe, or Celica, they will fit.Worst case, find out what car they are from and plug it into tire rack and look for new wheels. You'll see what the wheel's bolt pattern is by looking at it.But from the post, 14"s is too small unless you get smaller drums and discs...which would be a no-no in my opinion.
keithvibe
Post by keithvibe »
the bolt pattern is correct but the size is too small
Scootman!
Post by Scootman! »
Thanks for the help!
