Reliability of your Vibe...
zdkaiser
Post by zdkaiser »
Hello all,I just wanted to get some comments from you all about the reliability of your Vibe....How reliable has your Vibe been over the years? How many repairs, major/minor?How many miles on your car? Etc. etc.I just wanted to get any idea about how well these cars are built. Just mention what year/model your Vibe is.Consumer reports says they are great little machines.Thanks much..
NibCrom
Re: Reliability of your Vibe... (zdkaiser)
Post by NibCrom »
56,000 miles. Just oil changes.
Blueridge9
Post by Blueridge9 »
Quote, originally posted by zdkaiser » How many repairs, major/minor?....How many miles on your car? Etc. etc..... what year/model your Vibe is.....Consumer reports says they are great little machines.I bought mine used over 2 years ago in Feb of 2006 and now have 68,000 miles on it.Very reliable Toyota corolla engine 1.8L under the hood.Repairs: Only oil changes til routine maintenance at 61 K, auto. transmission fluid flush. Also replaced stock battery, waterpump, a few hoses at that time though they still worked but were declining.Window recall - GM replaced defective bolt for free. 2004 Base, Automatic 1.8L
Blueridge9 2004 Base, 1.8L "The Vibe is a melding of muscular looks, ..utility & economy, sportiness & road-hugging tractability." -Road & Track Magazine Sept. 2008 Pictures: http://s278.photobucket.com/user/blueridge9/library/" onclick="window.open(this.href);return false;
Blueridge9
Re: Reliability of your Vibe... (Blueridge9)
Another Viber reaches 299,999 miles in a 2004 base model: http://forums.genvibe.com/zerothread?id=33767
808 Vibes
Post by 808 Vibes »
FROSTY: a little over 22,000 miles and only oil changes, tire rotation and a replaced defective battery (warrantied) NEPTUNE: a little over 24,000 miles and only oil changes and tire rotation. We're so happy with them and WELCOME!
~ ALIS VOLAT PROPRIIS ~
hjwii
Post by hjwii »
2005 Vibe....169,598 miles...3 sets of tires (including crappy Continentals)3 windshields (stupid Katrina debris carrying trucks w/out tarps)1 battery33 oil changes (one every 5,000 miles)1 set of new brake pad thingies (or whatever they put on when your brakes get worn)16 tire rotations, give or take35 (or so) mpg...So, all in all, it's been about as reliable as one could hope. Which becomes a quandary... because soon I would like a new car. And I would like something different...bigger... But, then, I travel 150 miles per day, and I need it to be reliable, good gas milage. And I like the new Vibe... But really want a Flex or Acadia... woe is me...
rAERRK
Post by rAERRK »
2005 GT, purchased january 05 (new)37,000 miles. only tires/battery/other normal maintainance. no major repairs.edit - and it still smells new
Blueridge9
Re: Reliability of your Vibe... (rAERRK)
Quote, originally posted by rAERRK »edit - and it still smells new Sniff...sniff....oops I left my gym shoes in the Vibe and parked in the sun and now it does NOT smell so good.
ToolGuy
Post by ToolGuy »
Mine has been a great car! Other then normal maintenance, oil changes, trans fluid changed, plugs, tires and battery which is all normal for 60,000 miles. It was at the dealer twice, one was to replace the cat the other to inspect the tires. One repair recently caught me off guard though. I had to replace the drivers side window because a cheap plastic bracket broke and the bracket itself is not replaceable. This issue is also NOT related to the window recall. Since the bracket and glue are not replaceable, I had to buy an entirely new window for $127. I installed it myself and the glass place said many cars have this design not just the Vibes. This is not the cars fault and I do not hold it against the car, the car has been a great car!
ou.grizzly
Post by ou.grizzly »
148,000 miles +/-1. 2 sets of brakes2. 4 sets of tires3. 2 new head light bulbs4. 3 new wiper inserts for the rear5. 4 sets of wipers for the front windshield6. Oil Changes / Coolant / Trans Fluid7. Need to purchase a new master control panel for the drivers door (broke a few times)
isaaclud
Post by isaaclud »
2006 Vibe 5-speed base purchased new in '06.Currently 56,000 miles on it.Besides an oil change every 5,000...this car has neededNOTHING...The factory tires lasted me 50,000 miles(although i should have replaced them at 43,000)Oh, and to my shame I skipped an oil change andit went 10,000 miles without an oil change...still ran great though....No issues...no probs....(although it grinds a bit now sometimes when you pop it in reverse...no biggie)
PEACEISAAC
mbc
Post by mbc »
60K+, oil change(s), transmission change, new air filter(s), new cabin filter, new tires...
'06 Whte, basic, w/sunroof called Ms. Daisey.
Herb
Post by Herb »
I bought my GT in 2003. It has just over 78000km on it and I haven't had to take it into the shop for anything other than the power window recall and a faulty cigarette lighter outlet which were covered under warantee. The only exception was for collision repair.I do my own oil changes and it runs very well.
vibolista
Re: Reliability of your Vibe... (Herb)
Post by vibolista »
Hey zd, just check on the reliability stats of the Toyota Corolla. It's nearly bullet proof. Vibe/Matrix = Corolla + wagon body.
Kari
Post by Kari »
Almost 55,000 miles....6 years...no major problems. I had the catalytic converter replaced under the TSB but that is really the only "non-maintenance" work that has been done. The rest was cosmetic.
GenVibe Global Moderator
zdkaiser
Post by zdkaiser »
Hey... Thanks for the responses.I just purchased a used 2007 Wave Blue Vibe with 29K on it. I have only put on about 2500 miles and love the car so far. Just wanted to know what I might (or might not) have in store for my car. I am glad to hear the positive reviews.Need new tires soon. I am thinking Fuzion HRis or Yoko AVID H4s. Any suggestions?
808 Vibes
Re: (zdkaiser)
Post by 808 Vibes »
Congrats!! Pics..........pics......pics!!! It already needs new tires???
KNINE
Post by KNINE »
2006 5-speed with 60,000 miles. Everything is original, except the oil, air filter, and wiper blades. Yes, even the tires. No repairs required.
KNINE
Re: Reliability of your Vibe... (HawaiiPontiacLover)
Post by KNINE »
Quote, originally posted by HawaiiPontiacLover »FROSTY: a little over 22,000 miles and only oil changes, tire rotation and a replaced defective battery (warrantied) NEPTUNE: a little over 24,000 miles and only oil changes and tire rotation. We're so happy with them and WELCOME! Don'y fprget the new carpet.
808 Vibes
Re: Reliability of your Vibe... (K-NINE)
Post by 808 Vibes »
I didn't get new carpet, nerdy boy, I got new padding...AND new scratches.K-NINE is just jealous because he gets slightly less MPG than the rest of us with all the dog snout smudges on his windows. Less aerodynamic with all that dog snot, you know.
isaaclud
Post by isaaclud »
oh yeah.....i do have one BIG GRIPE...the paint on these Pontiac/Toyotas is horrible..my front end looks horrible.....(i do a lot of highway driving...but I wax GOOD3x a year too...)yet my chips and scratches are utterly out of control..its really disappointing....i dont know if i would ever buy another NUMMI car....
PEACEISAAC
vibolista
Re: (isaaclud)
Post by vibolista »
Paint chips are really not that expensive to fix... or you could put a bra on the front of your Vibe if you want less paint damage. Would much rather have a car that doesn't spend any time in the repair shop. That's a lot less expensive than a car with some sort of titanium based indestructible paint job needing frequent mechanical work. The durability of these Vibe/Matrix/Corolla (you pick) is nearly legendary.
Mavrik
Re: (vibolista)
Post by Mavrik »
From 2003 to 2007 when I owned my 04 Vibe, it was pretty much flawless. I had really only two issues that I probably caused myself. Over tightened the battery tie down and caused the battery to leak. Got that repaired under warranty. Not sure how but also damaged my MAF doing an intake change. Got a new one under warranty.A clunking noise developed in the front suspension and went away when I tightened all the front strut nuts. Never heard it again. The car made it across canada twice. Was auto crossed for a full season and drag raced occasionally.It was a very reliable car. My folks who own it now enjoy it. They had an issue with something in the back suspension. I wish I could remember what it was.
DownTheShore
Post by DownTheShore »
My 2005 Vibe just went off lease - 30,500 miles and all I had to have done were the regular oil changes and tire rotations and a set of new wiper blades. Best car I ever had. I think I sold another customer on a Vibe in the dealer's parking lot - lol.Just picked up a 2009 2.4L Vibe this week.
Life is simply one damned thing after another
high revin
Post by high revin »
Loving mine! Basic maintance 140,000 03 Abyss GT one brake cahange orignal clutch still drive it every day and work out of it!I have only run Mobil 1 oil in it!I too had to replace my drivers window as it exploded as i rolled it down had same plastic clip issue and a bolt fell out of it and exploded in my lap on a 33 degree day lol but just love how dependable its been and how well it works with me as i work in it !
DarkSpork
Post by DarkSpork »
2003 Vibe GT 37,000 miles :HVAC control unit is broken, I plan to replace it soon ($240), new battery, just bought new tires, need brakes, pretty much all wear and tear stuff. The car has started on the coldest of mornings when my friend's SUVs would not and has got me where I need to go without any problems.
2003 Pontiac Vibe GT
phoenixls2
Re: Reliability of your Vibe... (DarkSpork)
Post by phoenixls2 »
2004 Vibe103,300 milesI have put about 30,000 miles on her since purchasing. Not sure about previous work or maintenance, but we change the oil every 3,000 miles, I have put a new set of tires on her about 10,000 miles ago. New brakes (front) done around the same time. New O2 sensor back in May/June. Right now she is fine with no problems except I need to take it to the dealership so they can fix the driver-side window (plastic clips) and is driven daily between 40-100 miles (depends if I have to work or not).
~Jamie2004 Pontiac Vibe, silver
