Speaker Wiring Cornfusion
englishjg
Post by englishjg »
Hi. I just replaced my HU and removed my faulty stock amp. The HU replacement was fast, easy, and flawless... I have a 2004 Moon and Tunes (no navigation) system in my Vibe (I should say HAD)... anyway... When I removed the amp, I had to jumper the speaker wires at the connector, rather than cut wires.All the documentation I found out there that showed the wiring of the connectors were different than my actual wiring. For example, I verified that my Vibe has the UZ6 option on the factory sticker. I checked the UZ6 jack diagrams with Metra, and someone had posted some diagrams here with connector mappings. I ran into problems when trying to jumper the speakers. Bottom line, I manually mapped out my connectors, and they proved to be what Metra calls the "Pontiac Bonneville 2002-04 w/ RPO code UZ8" mappings.Has anyone else experienced this?Am I smokin' crack?It says Vibe on the outside of the car... Did I get a Bonneville by mistake?My Dad says I was switched at the hospital at birth... Was my car switched at the Dealer?Did they see me coming?Add your own Jimsults here...Thanks!!
Sublimewind
Post by Sublimewind »
Often times, connectors get used across the board... The schemes may be different, but the conectors are the same.... money savings....
