So my buddy just finished installing my fiamm horns. And what a difference and the 09 i didnt even have to drill a new hole for the second horn. not sure if the previous years had this i thought i read someone had to drill. Strongly recommended for anyone with the road runner horn still Meep Meep
The Horns were my, well, second mod. First was aftermarket cruise.The OEM Horn was litteraly laughable.I did not have to drill for mine either. Pics in the Garage.
are the horns just plug and play kind? i want to change mine to any aftermarket ones...should all horns just plug right up and will work?i used my horn for the first time and it was too embarassing...even my dad laughed
Quote, originally posted by lowincash »are the horns just plug and play kind? i want to change mine to any aftermarket ones...should all horns just plug right up and will work?(i'm assuming the 09 is the same as the older vibes, so you could follow this guide by ragingfishhttp://forums.genvibe.com/zerothread?id=2656
thanks i found that thread on my search...now i just have to order some horn...i might just get those aftermarket horn at autozones or something...anything will sound better than stock =/
