Possibly a bad axle?
THE VIBERATOR
Post by THE VIBERATOR »
My vibe has hit 70,000 miles recently and i am noticing a very loud creaking sound coming from the right front tire/axle area. Whenever i back out of my driveway and crank the wheel all the way to the left, i hear a rather loud creaking sound coming from my right front tire, i've checked the coil and the spring, they both seem fine, but i can't really tell if anything is rubbing or not. It also could be the tire itself rubbing against the damaged splashguard since the guard is about an inch closer to the tire than it should be (some idiot hit me). I also noticed that now, whenever i turn the wheel all the way to the left when not in reverse, i hear the same sound. It's starting to worry me. Any thoughts?
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
ragingfish
Post by ragingfish »
Fully remove the splash guard and see if you still hear those noises.
2009 PONTIAC G8
Raven
Re: (ragingfish)
Post by Raven »
It sounds more like an upper strut mount. Also check the sway bar bushings and end links. A CV axle usually makes a clicking, clacking noise when turning sharply at slow speed.
zionzr2
Re: (Raven)
Post by zionzr2 »
Quote, originally posted by Raven »It sounds more like an upper strut mount. Also check the sway bar bushings and end links. A CV axle usually makes a clicking, clacking noise when turning sharply at slow speed.+1
JohnC
Re: Possibly a bad axle? (THE VIBERATOR)
Post by JohnC »
I wouldn't rule out CV joints. I have heard them make all kinds of different sounds.
THE VIBERATOR
Re: Possibly a bad axle? (JohnC)
Thanks guys, i'll check all those out and let you know what i find.
THE VIBERATOR
I'm thinking the impact from when the idiot hit me may have destroyed my CV joint. I'm not ruling anything else out, but that's what I'm leaning towards right now.
