TRD Supercharger install guides on PDF
Supercharger, turbo, nitrous, and anything that has to do with forced induction
SoCal_CJ
Post by SoCal_CJ »
I found this here...it maybe old news but again I thought it might help a few folks..http://www.teamsotc.com/module...t=363and copied and pasted this part..Tom's Disclaimer : As always, I am not responsible for your actions. If for any reason your vehicle fails to operate normally after the installation of the Supercharger Unit, I cannot be held responsible for any damages caused by the person who performed the installation. All instructions are written to the best of the author's knowledge. Remember, this is for informational purposes ONLY and not an install guide. _____________________________________ I've created this thread based on my reasearch and install of the TRD Supercharger. There's a ton of information on different boards pertaining to the TRD Supercharger, so I figured I would create this and keep everything in one spot to make it easier for people in the future. I hope this information is as useful to you, as it was to me. Enjoy. Here are some files which I have accumulated through the past little while. TRD Supercharger Install Guide - Unit Install http://www.teamsotc.com/scinfo...l.pdf TRD Supercharger Install Guide - ECU Install http://www.teamsotc.com/scinfo...l.pdf TRD Supercharger Information Sheet http://www.teamsotc.com/scinfo...t.pdf I have also created a wiring guide for the E-Mange Blue Piggy Back Unit. Wiring Guide for E-Manage Blue http://www.teamsotc.com/scinfo...g.pdf The TRD Supercharger Toyota had created a supercharger kit for both the '03-'04 Matrix and Corolla. Nothing was available for the Celica from Toyota directly. Since the Celica 1ZZ-FE and the Corolla/Matrix 1ZZ-FE are initially the same engines, just slightly different fuel maps, the supercharger will work on the Celica with few modifications. GM also created a supercharger kit for the Pontiac Vibe, which again, is the exact same kit as Toyota's since the Pontiac Vibe 1ZZ-FE is the same as the Matrix/Corolla's. Here are the PART NUMBERS for the Toyota TRD Supercharger Kits: 2003 Matrix Auto 00602-17620-105 2003 Matrix Manual 00602-17620-106 2003 Corolla Auto 00602-17620-107 2003 Corolla Manual 00602-17620-108 2004 Matrix Auto 00602-17620-109 2004 Matrix Manual 00602-17620-111 2004 Corolla Auto 00602-17620-114 2004 Corolla Manual 00602-17620-115 Intake/Supercharger Metal Gasket PART NUMBER - 17171-0D010 Supercharger Fuel Line Banjo Bolt/Washers Banjo Bolt PART NUMBER - 90401-12097 Washers PART NUMBER - 90430-12005
