Look awesome as I have already said several times....lol. Glad you posted them up on here. Mine were ordered yesterday. Thanks again for being an AWD guinea pig. Nice watermark.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Just got back from having her alined... no problems this time.. everything was able to be moved in to speck ..... including my homemade oblonged top mount holes so i wouldn't need to use the aftermarket camber bolts... Anyone want to buy camber bolts??? HAHA
Quote, originally posted by keithvibe »Just got back from having her alined... no problems this time.. everything was able to be moved in to speck ..... including my homemade oblonged top mount holes so i wouldn't need to use the aftermarket camber bolts... Anyone want to buy camber bolts??? HAHANope! lol. When I had the Hotchkis springs, which were lower then the CM springs, I was able to get mine aligned without any modification to the Camber Bolts or the top mounting holes. So, it shouldn't be an issue this time around.
My Fleet:
you do realize the the front of our cars don't have a camber adjustment? correct... toe yes... no camber or caster adjustment though... the rears have toe, camber adjustment direct from the factory
Yes, I did. But when I had the hotchkis springs aligned they were able to get it into spec. It wasn't that far out after the springs were on and settled for 2 weeks. Not sure what they did. the Hotchkis springs were great at first but rode like crap after a year so I went back to stock. Hopefully these will be better in the long run since they have a lower spring rate for a smoother ride then the Hotchkis did. Can't wait until mine come in. This will make it my 4th time installing springs on my Vibe:1) Hotchkis (3"+ drop - on the AWD as it sits 1" higher than the 2WD stock...lol)2) Back to OEM3) Modified OEM and reinstalled (gave me a 1" drop rides much smoother than stock good handling too)4) Canuck Motorsports - COMING SOON - (Should provide the best of all worlds for the AWD with a better looking drop, a nice smooth ride (for a drop), and great handling like the Hotchkis)Local Install meet anyone??? Should only take a couple hours by myself...lol. It will probably take longer with more people but who cares!!! lol.
My Fleet:
Quote, originally posted by keithvibe »i love the ride B... you will too.. it took me about 5hrs with dismantling and reassemblyGood! OK, maybe more than a couple hours...lol. Last time I did it it took me 1 hour for each spring.PS: Mine are scheduled to be delivered ton Sept 10th. WOOT! Looks like I'll be installing them on the 13th.
My Fleet:
