Noisy exhaust??? or not??
Beclockwise
Post by Beclockwise »
I have only had this vibe for a month. 62K miles on it. I've always thought it ran a little too noisy for me, and I'm told the engine is used in Corolla's. I had the resonator replaced with a new one trying to quiet it down, but no difference. I think some of the noise comes from the intake side of things under the hood. Is it just the way it's supposed to be? At highway speeds it's not too noticable, but taking off from stops gets loud. Does that describe good enough?
kevera
Re: Noisy exhaust??? or not?? (Beclockwise)
Post by kevera »
Not real sure on the sound you are getting,I'd need a better description.Do you have an aftermarket intake on it?Does it sound like valvetrain noise?
keithvibe
Post by keithvibe »
gut the car and line every metal surface with sound deadner if you want it quite. my 2cents I did the very same thing
kevera
Re: Noisy exhaust??? or not?? (keithvibe)
Post by kevera »
Quote, originally posted by keithvibe »gut the car and line every metal surface with sound deadner if you want it quite. my 2cents I did the very same thingYou get used to the noise after a while.
Digger
Re: Noisy exhaust??? or not?? (kevera)
Post by Digger »
Check the air box under the hood. is the snorkel tube hooked up? A short ram intake will make it sound like you describe
Beclockwise
ya know, I came out of a fairly quiet Olds LSS to this Vibe. I may (as Kavera mentioned) eventually get used to it. The noise sounds like it comes from right underneath me. I think of it as a "growly" noise. I thought the car might have an intentionally loud exhaust, considering the diameter of the tailpipe. I also thought a lot of 4 cylinder cars were quieter than the vibe. I drove several before I bought my '03, so I guessed it was the design, but I wonder, ,has anyone ever tried a different exhaust design? Like off a Corolla?, or am I totally off base.
