Engine codes
CUV03
Engine codes
Post by CUV03 »
Anyone have info that shows engine codes and there meanings? Throwing 6 or 7 of them. When filling up the gas car almost stalled.
Mavrik
Re: Engine codes (CUV03)
Post by Mavrik »
most manufactures use the same codes... post up what your getting and I'll see what I can help with.
CUV03
Re: Engine codes (Mavrik)
Post by CUV03 »
I just got the codes checked again today and it is only throwing 4 now. Here they are: P0440, P0441, P0446, P0171.
Petrucci914
Post by Petrucci914 »
Vacuum LeakBad MAF SensorDirty MAF SensorDid you recent install a Cold Air Intake and over-oil the filter?
BlueCrush
Post by BlueCrush »
Quote, originally posted by CUV03 »I just got the codes checked again today and it is only throwing 4 now. Here they are: P0440, P0441, P0446, P0171.Try these links:http://www.obd-codes.com/p0440http://ww ... .com/p0171
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
CUV03
Re: Engine codes (Petrucci914)
Post by CUV03 »
No, same one I had in before I got any codes. Are all those codes related?
CUV03
Re: Engine codes (BlueCrush)
Post by CUV03 »
Links aren't working can you repost? Thanks.
also http://forums.genvibe.com/zerothread?id=10094the P044* ocould be the gas cap, 171 is a lean condition, that with the P044*, maybe a vacuum hose is off or cracked somewhere
CUV03
Re: Engine codes (joatmon)
Post by CUV03 »
One day while getting my tank filled my car almost stalled. (normally I shut off the engins) Does this indicate anything?
CUV03
Post by CUV03 »
Thanks for the link.
CUV03
Post by CUV03 »
After a repair is made do you have to get the check engine light reset?
engineertwin2
Post by engineertwin2 »
Typically, a service technician will reset the codes after they perform the repair, but often times, they clear the codes right after they read them. For a fuel filler cap issue, once corrected, it would reset the light after 3 driving cycles.Out of curiousity, what caused you to keep the car running while filling the tank? I don't know that I've ever seen anyone actually do it, but it doesn't seem like a good idea.
CUV03
Re: (engineertwin2)
Post by CUV03 »
Thanx for the info. Agreed, it's not a good idea. I was next in line at my usual gas station with my tank door open. While moving up to the pump the service attendent took the cap off and he started filling up my tank. Just at that moment the engine was trying to stall. I guess being that I frequent the same station they know what I get everytime. I told them they should wait until the car is stopped and off.
