Thanks for the links, Blueridge9.'05 Vibe (auto base of course) 30 - 33 MPG so far with AC on just about all the time. Still a newbie though.
2005 Vibe Base Platinum (Bought 7/12/08 - Sold 11/20/09)K&N / NGK Plugs / Blacked out arrows / Removed side emblemsScangaugeII / DRL red wire cutHankook K106 Tires on 16" ADR Battle Axe Gunmetal RimsKenwood DPX302 Head Unit / KSC-SW10 Powered SubKenwood TM-D700A Dual Band Amateur Radio and Garmin GPS
Question:I've had my Vibe for a couple weeks now. It seems to be shifting harsher. There is a definite "grab" when it shifts. At least I'm noticing it now. Especially at slow speeds. Normal? Something to keep an eye on? Perhaps it is just a smaller and lighter vehicle and I'm noticing the shift more than the heavier cars I've owned in the past.Thanks!
Quote, originally posted by abbotlex »Question:I've had my Vibe for a couple weeks now. It seems to be shifting harsher. There is a definite "grab" when it shifts. At least I'm noticing it now. Especially at slow speeds. Normal? Something to keep an eye on? Perhaps it is just a smaller and lighter vehicle and I'm noticing the shift more than the heavier cars I've owned in the past.Thanks!are you driving with gas down, then letting off the gas then going back on the gas? because mine would do that in that situation. Are you flooring it and its shifting up, are you keeping the gas pedal lightly pressed and letting it shift at 3k? need a little more info.
Light on the gas. Kind of like rolling through a parking lot then giving a little gas to pull onto a street. There is a hesitation and then wham, it's in gear. It doesn't clunk or make any noise. The RPMs don't go up, so it's not slipping.I saw in another thread about '05 models starting a "drive by wire" system. What's that about?
Personally i've never looked up the drive by wire and what it means.
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
Quote, originally posted by THE VIBERATOR »Personally i've never looked up the drive by wire and what it means.It means it has no cable controlling the throttle-body.
