Can 110 V and 12V outlets stay on with the ignition OFF?
Strobo43
Post by Strobo43 »
Does anyone know if we can change the 110 V and/or the accessory 12V outlets to stay on with the ignition OFF?My old Caravan had a relay to add into the fuse box that allowed one to have power on at ALL times.
2003 Base, Auto Trans, Moon and Tunes, Lava Monotone, Power, 16" Aluminum Alloy Wheels, VentShade Hood Delector. Add on Alarm by guy who installs "factory alarms" at dealer. Door and edge paint chips . Grafworks Vibe stickers, INJEN CAI still in the box . 65,000 miles since 04/03. Still using Mobile1 SINCE MY FIRST OIL CHANGE! Looking for new tires, wore out my Goodyear AssuranceComforTreds (replaced Eagles @27K). Thinking of the TriplTreds...
ragingfish
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (Strobo43)
Post by ragingfish »
The design calls for them to be disconnected when the power is cut to the car -- AFAIK, nobody has found a simple workaround for this yet, if any workaround has been found at all...
2009 PONTIAC G8
esjones
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (ragingfish)
Post by esjones »
quote:The design calls for them to be disconnected when the power is cut to the car -- I wonder if the '04 models are wired the same way.
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
stkos79
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (esjones)
Post by stkos79 »
theres a red/white wire off the power outlet switchif you run a fused 15 constant wire to it the unit willwork all the time but watch so you dont drain you batthopes this helps,,,
meathead333
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (stkos79)
Post by meathead333 »
quote:theres a red/white wire off the power outlet switchif you run a fused 15 constant wire to it the unit willwork all the time but watch so you dont drain you batthopes this helps,,,is that difficult, like will i kill myself? i miss that feature from my 2000 grand prix alot
My myspace.com profile My 73' Bronco Cardomain page
Strobo43
Post by Strobo43 »
OK, I understand that about splicing in a HOT wire and fusing it. So where is a good place to hook into a hot wire without goint to the battery, or that the best?? Is there an easy way to run a wire from the fusebox that is already fused and on all the time?
Strobo43
Re: Can 110 V and 12V outlets stay on with the ignition OFF? (silverawd26)
Post by Strobo43 »
What bigger size would fit our cars and do a good job?
