Hey everyone-I am looking at a set of drilled/slotted rotors on Ebay. They did have an auction for a set that had listed Vibe, but now that auction has ended. They have no other listings for the Vibe. But they do have a listing for Celica 01-05 for $107.99, or they have one listed for 02-03 Celica Matrix for $135.00, and ones listed for a tC 04-05 for $140. Am I correct that all of these would be the same and I would be safe to go with the Celica ones (that are cheaper!)?
I wanted to mention that the auction that had Vibe listed in it had stated it was for 03-07 Vibe & Matrix & 05-07 tC. So is it correct that tC rotors would be the same?The main one I'm wondering about is the Celica one's though, since they are the cheapest. HELP!
If I remember correctly,as long as they are for a GTS then you should be fine.Not sure about the TC ones though.As long as they are this size.Front Rotor Size: 275mmRear Rotor Size: 269mm
Quote, originally posted by kevera »If I remember correctly,as long as they are for a GTS then you should be fine.Not sure about the TC ones though.As long as they are this size.Front Rotor Size: 275mmRear Rotor Size: 269mmThe auction does not designate sub-models. It also does not state size of the rotors... so I have no clue... Maybe I'll just request another Vibe auction and see if they post it...
