aftermarket radio has no sound
katiejonesnc
Post by katiejonesnc »
got the wires correct but there is no sound. I have an '04 vibe. the auto place made some calls and everyone thinks that he is crazy and don't believe that there is no sound. he thinks he will have to test each factory wire to find it, any suggestions?
Whelan
Re: aftermarket radio has no sound (katiejonesnc)
Post by Whelan »
If I'm not mistaken the radios changed from 03-04 to 05+. Be sure you are using the right harness for the model of the car.
2012 GLI Autobahn 6MT
Re: aftermarket radio has no sound (Whelan)
The radios have evolved over the years, but the pinouts for 03 - 08 are the same for VIbes. I don't know about the 09's.The Matrix radios changed radically in 05Is the car a basic system, or does the car have the Moon&Tunes package?
Kevzaz
Post by Kevzaz »
Does it turn on? Change the ground and see if it fixes your situation.
skylinedrifter
Post by skylinedrifter »
Also, a lot of aftermarket heads let you turn on/off the internal amplifier in the event you are sending the signal to an external amp. Check for that, too
Sublimewind
Post by Sublimewind »
More info is needed, we are just speculating.. Like Joatmon stated, did it have either of the "preium" audio systems in it? You say auto place... What KIND of auto place, was it an install shop or just some muffler shop...lol... If it was an actual install shop, I would RUN, not walk away from that place, if they couldn't get the install correct... they should know, or have the ability to find out all the info needed to get the job done... was the stereo NEW or USED?? What kind of stereo, and what model #... ? It is quite possible that one or more of the speakers is blown, and/or possibly shorted... not very probable though... answer some questions and possibly get some answers..
Re: (Sublimewind)
Quote, originally posted by Sublimewind »answer some questions and possibly get some answers.. easy now, give her some time
Sublimewind
Re: (joatmon)
Quote, originally posted by joatmon »easy now, give her some timeOh, I am mang.... Just stating the obvious... NEED MORE INFO... lol...
magickarle
Re: (Sublimewind)
Post by magickarle »
I got the same problem.I got a wire hardness installed and connected all color coded wired A1.The radio turns on, off and able to tune to FM no problem (since there's a status light for FM tuning).I reconnected the old radio and the music was back.I think there's an amp (looking under driver seat).I've attached the wiring diagram on the radio with amp in case someone could help me.There's 2 sets of wire hardness for the OEM radio. I'm not sure what is the second one for.I'll post soem pics tomorow.Cheers
Attached files WD_GM_019434.pdf (138.9 KB)
04 Vibe automatic AWD.Mods done:Cosmo CAI | Bazooka sub | Alutec Crank Pulley.Comming mods:Greddy eManageRepair done:Belt changed.Hood painting (rocks chips)Repair comming-up:Head gasket
Re: (magickarle)
If you have the Moon & Tunes package, it sounds like you might not have power to the amp turn-on lead. As a result, the radio will turn on but you won't get any sound since the external amp will still be off. Check this thread for help with this.
Image Image
Sublimewind
Re: (ColonelPanic)
Quote, originally posted by ColonelPanic »If you have the Moon & Tunes package, it sounds like you might not have power to the amp turn-on lead. As a result, the radio will turn on but you won't get any sound since the external amp will still be off. Check this thread for help with this. +1
