Oxygen Sensor.. Help me :)
robertinsandiego
Post by robertinsandiego »
Hello gents, I'm a newbie. I need help with how to change a o2 sensor on my 2006 vibe. Any help or links, would help. If this is something I can do with my cousin who's good with these things, or should I take it to a mech. I've been getting a P0171 code for a while now. and now my mixture seems to be off, trouble starting ( battery is fine, CAI, is tight, and working properly) basically when I gass it at 3k rpm, it boggs.. I"m thinking the mixture is off because of the O2. Any thoughts and help could help me greatly..Thanks.Rob
Celtic_Curse
Re: Oxygen Sensor.. Help me :) (robertinsandiego)
Post by Celtic_Curse »
IF I didn't know better I'd say you fried your MAF during the CAI install. Does it idle really rough?
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Raven
Post by Raven »
Disconnect the battery for a while. Clean the MAF sensor with electronic or brake cleaner, don't touch the fine wire, just spray it. Run a tank or two of Techron fuel injector cleaner and see what happens. There's no way the O2 sensor should be toast yet. Apparently quite a few people with DBW throttle body Vibe's get this code with a CAI. My '06 never did. I'm assuming it's a Cosmo CAI, right? Did you oil the filter?
RIT
Re: Oxygen Sensor.. Help me :) (Raven)
Post by RIT »
How can you make a blanket statement that "there is no way that the O2 sensor should be toast yet" - we're talking "electronics" - they can fail early - unlikely, but $hit happens.
Sublimewind
Post by Sublimewind »
Quote, originally posted by Raven »Disconnect the battery for a while. Clean the MAF sensor with electronic or brake cleaner, don't touch the fine wire, just spray it. Run a tank or two of Techron fuel injector cleaner and see what happens. There's no way the O2 sensor should be toast yet. Apparently quite a few people with DBW throttle body Vibe's get this code with a CAI. My '06 never did. I'm assuming it's a Cosmo CAI, right? Did you oil the filter?Quote, originally posted by Celtic_Curse »IF I didn't know better I'd say you fried your MAF during the CAI install. Does it idle really rough?Agreed, I would start with the MAF... as stated here, the 171 code points to the MAF first.. http://www.obd-codes.com/p0171 and the O2 sensor is detecting a lean condition.. Most all O2 sensors require a special socket to replace them, it has part of the side cut out so the wire can pass through it.. you can get the socket on loan from AutoZone..
robertinsandiego
guys...! thanks for all the responses, well, I cleaned the MAF, it'f fine, I put in a fuel injector cleaner solution (on only a half tank), and literally all this happenned AFTER that, I figured it was too strong so I filled up the tank (with same fuel and octane) 91, . So , this is where I"m at, "FUEL FILTER" I believe that something is clogging it that has gotten broken loose. Any thoughts? Because now, when I turn it on when it goes down to low idle, it just sounds BOGGY, and when I give it gas, there is a delay then slight rev. into the higher RPMs, then when it comes down to low, it shuts off.. Sounds like fuel problem? thanks again guys.Oh, and where the hell is the fuel filter on a 06'? back by the rear axle, after the gas tank? thanksRob
robertinsandiego
Re: Oxygen Sensor.. Help me :) (RIT)
I cleaned it, still happenning. I'm gonna change the fuel filter out, just need a exact location.
robertinsandiego
Nevermind.. hha. it's in the tank.. I think, the gas is too lean with tthe cleaner in it, and the CAE (Cosmo) on it as well.. I'll keep you guys posted.. thanks again.rob
keithvibe
Post by keithvibe »
are you a gt, base, awd???
keithvibe
Post by keithvibe »
sounds like the car is in limp mode if it's boggin at 3k... reset your computer and run threw three start stop cycles, min 75miles to see if the code it thrown again.
Celtic_Curse
Talking from experience when I fried my MAF...I'd say yours is toast. Mine did the exact same thing ad same symptoms when I arcked the positive terminal on my battery to the CAI accidently.
