There is a LED brake light replacement and there is also a VIBE overlay for the brake light. But not a LED brake light that lights up VIBE all in one.You could get the overlay and stick it on the brake light. Or you could get the LED replacement and then stick the overlay on that.
Thanks! I sure thot I saw something like that here back in '06 when I bought the car. Must have been the overlay you mention. Seemed like a good idea, tho.
you probably saw the overlay...there are however replacemetn led third brake lights that someone makes...anyone have any pics of the led third brake lights to use as example?....also whatever happened to them...did anyone ever work out the issue with fitting them properly or whatever...something about them fitting better in the matrix then the vibe?
http://www.thexenonstore.comYou can get the LED 3rd brake from there, it's a plug n' play and I love mine. Although I had to wait a month cause he used my lamp as the template, but who cares, I got mine for free. Worth the $30 though if you have it.
I looked on website. Is is really no too difficult to install and keep mounted so you don't have shaking, etc. ? Looks like a nice mod on the site. Thanks.
I had to trim the circuit board a bit as it didn't quite fit the housing right, but other than that it works fine!I have the overlay on it as well but didn't take a photo of it before I was rear ended.Car's going in the shop tomorrow. I'll see it when I get back from vacation. Should have the spoilers on as well so look forward to seeing some pictures!
i got mine off ebay. it only has 2 rows of led, but it was made for the vibe. at any rate, easy install guys, plugs directly into the socket that the normal bulb would plug into.
de-badged o4 vibe
o2 triumph speed four
