Here is my problem guys I want to remove my upper spoiler, do you know how to/ or is it possible to remove the metal piece that the spoiler is mounted to so that I would be able to fill the holes in. Or is that piece part of the tailgate. Thanks
Hi WagonMafia,I do believe that comes off. Open the hatch window, you should see the bolts somewhere near where the bolts for the Spoiler is. On a side note, My after-market spoiler came with plastic plugs for the holes just in case I ever took it off. I also saw similar plugs at Lowe's so you may be able to just plug them if you find the right size. These plugs are less than $2 a piece, I believe.Dave
as far as I can see the peice can be removed since its on a pivot im not to sure though I havn't opened up my back window in a very long time haha so why are you taking off the back spoiler if you dont mind me asking??
