Wanted: Seamstress?
Herb
Wanted: Seamstress?
Post by Herb »
It looks like my Vibe GT is coming apart at the seams.Well specifically the stitching on the sleeve of my shifter. So do dealers re-sew bad stitching?
Triton
Re: Wanted: Seamstress? (Herb)
Post by Triton »
As far as I know, they don't. But the warranty should cover that. Have them order you a new one and replace it. I can't believe it is coming apart already!
***SOLD***2003 Vibe GT Monotone Neptune - Inaugural October 2004 Vibe of the Month***SOLD***
Now the proud owner of Titanium Silver 2012 Kia Optima SX
slbpsi63
Re: Wanted: Seamstress? (Salsa!)
Post by slbpsi63 »
If you have a base vibe its made out of a cheap material. I suggest you replace it with a leather boot. If not you'll end up replacing it again.
Base Vibe, Shadow Monotone, 5sp.
rasermon
Post by rasermon »
quote:Or you're using it for other purposes
Triton
Re: Wanted: Seamstress? (slbpsi63)
Post by Triton »
quote:If you have a base vibe its made out of a cheap material. I suggest you replace it with a leather boot.He had stated that he had a GT. Are the boots in the base Vibe vinyl or something? The boot in the GT is leather and the dealer should replace it, no questions asked. Especially with how new the car is.
cohocarl
Post by cohocarl »
Mine was unraveling from day 1. I planned on putting a small drop of superglue on the threads to keep it from going any further, but I haven't.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
bh357
Re: Wanted: Seamstress? (cohocarl)
Post by bh357 »
Mine's been unraveling a bit also. I have a GT and am already up to 30k miles. Probably mention it to the dealer next time I take the car in. Well, I guess I'm not the only one having this problem.
dmitri
Post by dmitri »
I'm kind of unhappy with my vibe gt...im thinking I should have gotten a different car. It's quality in some areas is kind of ****ty. I've had it for 2 months now, 2000 miles on it now I think. I already have an oil leak, speaker rattles, and I don't like the way the trans is set up in terms of where 1st and 2nd are. It's also annoying to shift from 5th to 4th because you hit the gate.
ragingfish
Re: Wanted: Seamstress? (dmitri)
Post by ragingfish »
quote:I don't like the way the trans is set up in terms of where 1st and 2nd are. It's also annoying to shift from 5th to 4th because you hit the gate. Didn't you test drive the car before you settled on it?
2009 PONTIAC G8
