UN pully + Supercharger?
Supercharger, turbo, nitrous, and anything that has to do with forced induction
Lancer
Post by Lancer »
What would the Unorthodox pully do to the super charger? Would it increase the boost at all? Just trying to get a plan together for when the S/C does come out.
NovaResource
Re: UN pully + Supercharger? (Lancer)
Post by NovaResource »
Underdrive pulleys make horsepower by slowing down the accessories making them easier to turn.If you add a supercharger, the underdriver pulleys would slow down the supercharger creating less boost and less horsepower improvement.
Triton
Re: UN pully + Supercharger? (NovaResource)
Post by Triton »
Are adding pullies to a GT worth it? What do you think Scott?
Pablo1669
Re: UN pully + Supercharger? (Triton GT)
Post by Pablo1669 »
quote:Are adding pullies to a GT worth it? What do you think Scott?good question. I am seriously considering making that my next mod. I've never read that they slow down the accessories. I always thought they just reduced weight, making them take less draw from the engine to turn.
-Brian
Pablo1669
Post by Pablo1669 »
Being very interested in how they work, I looked up some info from AEM. Here is a link to their page for the pulleys. You can read up on them there. http://www.aempower.com/product_pulley.asp
-Brian
d_m_kolb
Re: UN pully + Supercharger? (Pablo1669)
Post by d_m_kolb »
I have spoken to a Pontiac contact I have and was told if you could have a aftermarket pulley made that would speed up the Supercharger, this would in turn make the engine produce more HP. You'd need a smaller diameter size pulley installed on the supercharger which would make the unit spin faster creating more PSI. The 1ZZ-FE can handle 10 PSI and the computer that will be installed with the Supercharger will be able to adjust itself for the higher amount of PSI being generated. The stock PSI will be 7.5 PSI.The top PSI I'd run is 12. It should be able to handle this. I wouldn't go any higher. I was told the computer will be able to adjust to just about any PSI though.
Wrx-2-Vibe
Post by Wrx-2-Vibe »
there was a company that made pullines for the superchager GM 3800 v-6's, they fit the pontiac GTP's and Buick GS's, Dam I can't remember the name. BUt basically yup it's kick in a few ponies! Not sure what it'll do the the old warrenty (but its easliy removed, and you can erase stored codes b4 any dealer maintinace)hummmm
2003 AWD Vibe (frosty)18' Sports Edition (fox 2's)Eibach Sports Springsde-emblem'dSport Package carbon fiberhood Flowmaster exhaustOther Rides:*************************74 Benz 450sl (43K original miles)02 Yamaha V-Star 43 Willy's Jeep03 Jeep Grnd. Cherokee
MadBill
Re: UN pully + Supercharger? (Wrx-2-Vibe)
Post by MadBill »
Here's a few sites that list pulleys for the 3800 SC. There's one that has some dyno results with up to ~20 psi!http://www.pfyc.com/store/merchant.mv?S ... mance.com/
Faultline
Re: UN pully + Supercharger? (Admin II)
Post by Faultline »
[QUOTeYou'd need a smaller diameter size pulley installed on the supercharger which would make the unit spin faster creating more PSI. The 1ZZ-FE can handle 10 PSI The top PSI I'd run is 12. It should be able to handle this. I wouldn't go any higher. I was told the computer will be able to adjust to just about any PSI though.[/QUOTE]Wasnt there a problem with the the SC pully being as small as can be already?..Small enough to make the belt jump if made smaller, or needing the addition of a belt tensioner if made smaller?..or..actually getting a larger crank pulley, and smaller ones for all the accessories?
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
Lancer
Re: UN pully + Supercharger? (Faultline)
Post by Lancer »
Now I'm leaning more towards the turbo kit. I think the main question I have to keep me with the S/C is, besides using a smaller pully can you tune a S/C to produce more of a boost (like 10-12 psi) ? Or would I have to use nitrous in addition to get my car over 200hp?
Geo
Post by Geo »
If you were to increase the boost from 7.5 to say 10 PSI, how would that effect the automatic transmission? Is it beefy enough to handle the extra boost?
BADGER PRIDE
